Memory card file system not identified
http://forum.hddguru.com/viewtopic.php?f=10&t=43816
Author:  higgsboson [ November 10th, 2023, 0:17 ]
Post subject:  Memory card file system not identified
2GB microsd card is having severe file system corruption and none of the recovery software is able to identify any file system or any raw data.
attached is snpshot & first 50mb sectors.
can someone pls help.
download https://drive.google.com/file/d/13eZFRe ... sp=sharing
Author:  fzabkar [ November 10th, 2023, 2:25 ]
Post subject:  Re: Memory card file system not identified
The file compresses to 23KB, so it contains no data. In fact the block at 0 - 0x3FFF is repeated from beginning to end.
Author:  higgsboson [ November 10th, 2023, 4:50 ]
:good: Thank you fzabkar
Author:  Lardman [ November 10th, 2023, 4:57 ]
Did you read that in a card reader or via nand protocol ?
Author:  einstein9 [ November 11th, 2023, 2:11 ]
@ higgsboson
Most probably Controller issue, going crazy
since this is MicroSD Monolith more complicated than you think
Author:  arvika [ November 11th, 2023, 4:59 ]
I think chip-off reading will help for such case.
Author:  higgsboson [ November 11th, 2023, 10:15 ]
wow all super experts from our forum like fzabkar ,einstein9,Lardman & digital man arvika gave suggestions then probably controller will automatically self repair itself .
Thank You so much for extending your expertise for such small case.
Yes Lardman I have read it through card reader only as I don't have expertise to directly work on nand protocol ,chip-off etc.
I thought its simple file system corruption as customer put card in another mobile & it started giving error.
May be working life of the card was long over it is not giving any error.
Thank you all.
