 Post subject: Samsung 860 evo m.2 schematic sheet?
PostPosted: December 25th, 2023, 21:27
I'm working on repairing a samsung 860 evo m.2 1tb ssd, does anyone know where I can find a schematic for this drive? I just need to know the voltages and whatnot of each capacitor, resistor, etc in the drive so I know what to buy to replace it. Thanks!
 Post subject: Re: Samsung 860 evo m.2 schematic sheet?
PostPosted: December 25th, 2023, 21:49
Upload detailed photos and someone will show you what to measure.
PostPosted: December 25th, 2023, 23:04
I know what to measure, it’s just shorted out so I do not know what the original resistance was
PostPosted: December 25th, 2023, 23:36
To me it sounds like you don't know where to start. If something is shorted, then removing it will release the short. You don't need a schematic for that. There are plenty of threads that show you what to do.
In any case, you won't find a schematic anywhere, unless someone has produced their own.
PostPosted: December 25th, 2023, 23:41
I mean I know I have to remove the short and then replace the shorted component, I just want to make sure that I replace the shorted component with the correct one. Thanks for the info on the schematic though
PostPosted: December 25th, 2023, 23:59
These might help:
https://web.archive.org/web/20230522144629/http://www.users.on.net/~fzabkar/Datasheets/DATAURLS.HTM
https://web.archive.org/web/20230522152022/users.on.net/~fzabkar/Datasheets/datasheets.txt
