Post new topic Reply to topic  [ 94 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: Toshiba m2 died
PostPosted: December 30th, 2023, 17:24
After laptop battery replacement, the ssd is not recognizeble by the bios.
I inserted the ssd drive in a m2 enclosure and nothing shows up.
I measured all the caps, nothing shorted. I found an small ic broken on the side. I also checked the disk with thermal camera and it looks like its dead. I cant measure any voltages at any point.
File comment: Left side is the enclosure temperature
 Post subject: Re: Toshiba m2 died
PostPosted: December 30th, 2023, 19:26
What are the voltages at the input and output of the e-fuse or current-limited load switch?
What are the voltages at each of the inductors adjacent to the PMIC?
PostPosted: December 30th, 2023, 19:38
I have m2 enclosure and testet all the voltages while it was connected to my pc, but i dont found any voltages. I dont understand why it doesnt get any voltages. If i take the m2 and insert my own harddrive kn enclosure, everything works
PostPosted: December 30th, 2023, 19:42
NX5P2924UK, NXP, Logic controlled high-side power switch, 0.8V - 5.5V, 2.5A, 1.2V control logic, marking 24, WLCSP6
https://www.nxp.com/docs/en/data-sheet/NX5P2924.pdf
PostPosted: December 30th, 2023, 19:44
So, is there are short between ground and the 3.3V input?
https://www.hddoracle.com/viewtopic.php?p=18130#p18130
PostPosted: December 30th, 2023, 19:47
So you found that broken ic? Wow how? That makes sense since i cant measure anything on components
PostPosted: December 30th, 2023, 19:49
That broken IC probably has nothing to do with the root cause.
Is there a short between 3.3Vin and Ground?
PostPosted: December 30th, 2023, 19:52
Im not sure about where to measure the 3V input. Is it on the pins where the notch are? Bottom side is gnd and top 3V?
PostPosted: December 30th, 2023, 19:58
m.2 pinouts:
https://www.hddoracle.com/viewtopic.php?f=106&t=2506
PostPosted: December 30th, 2023, 20:05
No, there is no short between 3V and gnd.
Screenshot_2023-12-31-01-05-12-88_965bbf4d18d205f782c6b8409c5773a4.jpg [ 1.22 MiB | Viewed 78530 times ]
Screenshot_2023-12-31-01-04-35-25_965bbf4d18d205f782c6b8409c5773a4.jpg [ 1.24 MiB | Viewed 78530 times ]
PostPosted: December 30th, 2023, 20:06
No, there is no short between the 3V and GND
PostPosted: December 30th, 2023, 20:19
RT5045A, Richtek, Power Management Unit Total Power Solution for SSD, 6x step-down converters, 1x LDO, 2.9V - 5.5Vin, WL-CSP-52B:
https://www.richtek.com/assets/product_file/RT5045A/DS5045A-00.pdf
PostPosted: December 30th, 2023, 20:22
I wrote to times but it told me that admin need to prove.
There is no short between 3V and Gnd
PostPosted: December 30th, 2023, 20:35
TPS22965, Texas Instruments, 5.7V, 6A, 16mO Load Switch With Adjustable Rise Time and Optional Quick Output Discharge, marking ZSA0, 8-pin:
http://www.ti.com/lit/ds/symlink/tps22965.pdf
PostPosted: December 30th, 2023, 20:44
Here are some pic
Screenshot_2023-12-31-01-05-12-88_965bbf4d18d205f782c6b8409c5773a4.jpg [ 1.22 MiB | Viewed 78740 times ]
PostPosted: December 30th, 2023, 20:45
Backside
Screenshot_2023-12-31-01-04-35-25_965bbf4d18d205f782c6b8409c5773a4.jpg [ 1.24 MiB | Viewed 78740 times ]
PostPosted: December 30th, 2023, 20:55
Picture 1
Screenshot_2023-12-31-01-50-52-88_965bbf4d18d205f782c6b8409c5773a4.jpg [ 1021.48 KiB | Viewed 78724 times ]
PostPosted: December 30th, 2023, 20:56
Picture 2
Screenshot_2023-12-31-01-51-29-00_965bbf4d18d205f782c6b8409c5773a4.jpg [ 1.29 MiB | Viewed 78724 times ]
PostPosted: December 30th, 2023, 20:57
Picture 3
Screenshot_2023-12-31-01-51-37-03_965bbf4d18d205f782c6b8409c5773a4.jpg [ 1.3 MiB | Viewed 78724 times ]
Picture 4
Screenshot_2023-12-31-01-52-05-78_965bbf4d18d205f782c6b8409c5773a4.jpg [ 1.38 MiB | Viewed 78724 times ]
