Flash drive with a unbranded UP21 controller.
Posted: February 2nd, 2024, 15:01
I got this no-name USB drive for repair with an not branded UP21 48-pin controller, whose connector was violently ripped off, with tracks coming together. The flash drive was not in use when the accident occured.
I am now awaiting an identical flash drive that my client could find recently, so that I will have all necessary parts for the repair or a chip transfer. So, my question is just out of curiosity, to confirm that my diagnosis is correct.
I did a first repair with the original connector, which was unsucesseful.
So, I desoldered it, took a photo of the tracks and put a new connector into place.
The 1.5Ω (1R5) resistor near the positive pin had to be replaced by a resistor of the same value because the metal was no longer attached to the ceramic. The replacement resistor was taken from a dead USB drive from my trash of electronic boards, and consequently is possibly defective.
I bridged what could be, and re-tined the pads of the controller and NAND chip.
The flash drive is still not detected: no sound when connecting it in Windows and not visible in the disk management.
On the positive pin, the voltage is well around 5.07V, and is 2.76V after the 1.5Ω resistor.
So, the controller is powered with 2.76V.
The UP21 controller of the flash drive has :
- VCC on pin 47
- D- on pin 42
- D+ on pin 43
- GND on pin 41
This is similar to the pinout of the Phison PS2251-67 controller
So, I assume 5V being expected on pin 47 and the 1.5Ω resistor being defective.
Just wanted to confirm my hypothesis that there currently is a problem of insufficient VCC to the controller.
- VCC on pin 47
- D- on pin 42
- D+ on pin 43
- GND on pin 41
.So, I assume 5V being expected on pin 47 and the 1.5Ω resistor being defective.
