 Post subject: Samsung 850 PRO 128GB Won't Initialize
PostPosted: February 7th, 2024, 22:07
Hello, I have a 128GB Samsung 850 Pro SSD that went dark on me. Was my main OS drive and I have a couple documents that I'd like to get back if possible. I've tried different SATA, external SATA cable, and taken it to a nearby shop and they can't seem to get it to initialize or register to windows. When I am in the disk management window it shows up as "Disk 4" and when I initialize it says "The request failed due to a fatal device hardware error". There was another shop who said the data is recoverable but cost was too high.
I looked into some forums and saw that there is an e-fuse on this model (no TVS diode). Looking at the e-fuse chip when powered I have 5V at input and 5V at the output of the chip. This is where I'm not sure where to continue troubleshooting. I'm an EE by trade and if I had a schematic I'd be all up in it. Can solder, measure, etc. Just need direction! Any help out there?
This link sprung me down a road of troubleshooting to some degree: https://forums.tomshardware.com/threads ... ge-2#posts.
Thank you!
 Post subject: Re: Samsung 850 PRO 128GB Won't Initialize
PostPosted: February 8th, 2024, 6:16
You can check the voltages at the inductors around the PMIC - there are no drive schematics other than ones we create in house.
Given it's age and use this is likely to be a firmware issue caused by the nand degrading rather than an electrical problem. Best to send it in to a pro as it's a supported model shouldn't be much more than 300 USD.
PostPosted: February 10th, 2024, 16:21
https://forums.tomshardware.com/threads/samsung-850-pro-128gb-wont-initialize.3836146/post-23198748
Users browsing this forum: No registered users and 129 guests
