HDD GURU FORUMS
http://forum.hddguru.com/
2TB USB Flash
http://forum.hddguru.com/viewtopic.php?f=10&t=44103
Page 1 of 1
Author:  Ihab [ February 14th, 2024, 6:42 ]
Post subject:  2TB USB Flash
Hello guys!
I have this USB flash whats marced with 2TB (i dont think its actually 2TB) and it just recognize the controller.
So i wanted to work on it with the PC3k Flash but i dont have the PIN layout..
Maybe someone of you guys would sell it to me and/or can give me some advices about this USB flash?
I am new at working with the flash so i would appreciate any advice!
Thank you!
Greets, Ihab.
Author:  arvika [ February 14th, 2024, 9:56 ]
Post subject:  Re: 2TB USB Flash
Let me quess... is it FC controller? Usually it use 32/64GB memory chip. Looks like common refurbished device. Pinout is the simplest part.
Author:  Ihab [ February 14th, 2024, 10:58 ]
arvika, thx for reply. I am not sure to be honest.. first time working on this fake stuff...
But i guess when i solder the pins on the multiboard.. it coukd be possible to read the information like size and Chip ID.
Author:  arvika [ February 14th, 2024, 11:43 ]
You can try check the controller and ID by ChipGenius if flash is still little alive.
Author:  Ihab [ February 14th, 2024, 11:57 ]
arvika, This is what i got:
Author:  arvika [ February 14th, 2024, 13:27 ]
As I excpect controller is FC - Firstchip. So far I have one case with this chip - it was solved. Memory was 128GB, 6th byte addressing.
Author:  Ihab [ February 15th, 2024, 3:16 ]
arvika, i will sent you a PM.
http://www.phpbb.com/
