HDD GURU FORUMS
http://forum.hddguru.com/
SP S55 - SATAFIRM S11
http://forum.hddguru.com/viewtopic.php?f=10&t=44340
Page 1 of 1
Author:  Pi0tR [ May 28th, 2024, 14:52 ]
Post subject:  SP S55 - SATAFIRM S11
Hi i have Silicon Power S55 with SATAFIRM S11 Error
im trying to boot this drive in save mode via MRT (short two pins on PCB) but disk is not ready
what am I doing wrong ?
Author:  ccc [ May 29th, 2024, 1:20 ]
Post subject:  Re: SP S55 - SATAFIRM S11
Try to not short anything, power on the drive and enter the utility...does it work? Or it goes to BSY state?
Author:  Pi0tR [ May 29th, 2024, 3:49 ]
pins not shorted
and nothing more, unfortunately
Author:  fzabkar [ May 29th, 2024, 4:11 ]
Check the 3 supply voltages. Perhaps a missing NAND Vcc supply might produce the same symptom???
Author:  ccc [ May 30th, 2024, 1:33 ]
Ok. Show us the same screenshots but this time with pins shorted.
Author:  Pi0tR [ August 26th, 2025, 14:53 ]
im back to topic
wittout shorting i see this
Author:  vx1 [ August 26th, 2025, 16:15 ]
Create the translator at this point and in the DE use "Read form active MRT Utility" as normal.
Author:  Pi0tR [ August 27th, 2025, 11:01 ]
100% sucess, thanks a lot !
http://www.phpbb.com/
