 Post subject: PWR off for an SSD drive
PostPosted: June 11th, 2024, 7:53
How to deal with an SSD when the PWR is OFF in PC3000 (even if you shortcut it).
Is there a way to fix it, or do you need to move the controller + chips to the same model SSD?
Than you in advance
 Post subject: Re: PWR off for an SSD drive
PostPosted: June 11th, 2024, 12:54
Measure the voltages between each inductor and ground. Chip transplants are for mechanics, not electronics technicians.
PostPosted: June 12th, 2024, 8:46
Thank you for your help.
Could you please show the points on the PCB? I have limited knowledge of Electronics :roll:
Thank you in advance.
PostPosted: June 12th, 2024, 12:03
Ground is any screw hole.
Inductors are those ferrite bodied components adjacent to each of the 3 DC-DC converters. The inductors are shaped like squares with chamfered edges.
PostPosted: June 13th, 2024, 2:19
Hi fzabkar,
Are you talking about those 2 components?
Thanks in advance for your help.
PostPosted: June 13th, 2024, 2:42
https://image.made-in-china.com/44f3j00yTLlFbnWkSrv/Surface-Mount-1uh-Ferrite-Core-Power-Coil-SMT-Nr8040-1r0-Power-SMD-Inductor-for-Digital-Movie-Cameras.webp
Users browsing this forum: No registered users and 21 guests
