HDD GURU FORUMS
http://forum.hddguru.com/
Apacer Panther AS350 512GB, 2.5" / SATA 6Gb/s
http://forum.hddguru.com/viewtopic.php?f=10&t=44516
Page 1 of 1
Author:  mhp666 [ July 29th, 2024, 6:50 ]
Post subject:  Apacer Panther AS350 512GB, 2.5" / SATA 6Gb/s
I have an Apacer Panther AS350 512GB, 2.5" / SATA 6Gb/s, which is busy and I use MRTLAB 2.1.9.3 as a tool.
Does anyone know if this unit can be made with MRTLAB?
Author:  Lardman [ July 29th, 2024, 9:35 ]
Post subject:  Re: Apacer Panther AS350 512GB, 2.5" / SATA 6Gb/s
It looks to supper the controller https://us.mrtlab.com/SSDDE/314.html
PC3000 ssd has support.
Author:  mhp666 [ July 29th, 2024, 11:07 ]
Thanks for the reply.
With MRTLAB I get the following results:
Selected family : ............................: Silicon Power Slim S55 (SM2258XT)
Master Controller model : ....................: SM2258XT
Chip id : ....................................: 0xEC119B3F8ECB
Vendor : .....................................: Samsung
SSD state:
Wether it is in a ready state : ..............: Yes
Firmware working mode : ......................: ROM
SSD error code : .............................: 0x00(No error)
Whether SSD is locked  : .....................: No
Whether in safe mode : .......................: Yes
Whether access user area : ...................: No
Whether access SA  : .........................: No
Load loader...
Default Loader name : ........................: S0212B0 SSV3_00
Write default Loader : .......................: success
Load default Loader code : ...................: success
Obtain Loader version from firmware : ........:
Read Loader : ................................: success
Loader name : ................................: S0212B0 SSV3_00
Write to Loader : ............................: success
Execute Loader code : ........................: success
SSD state:
Firmware working mode : ......................: LDR
Whether in safe mode : .......................: No
Whether access SA  : .........................: Yes
Load loader : ................................: success
Basic SSD information:
Read chip information : ......................: success
Flash type : .................................: 3dv4-64L QLC 32k
Chip capacity : ..............................: 34224 Mb
channel number : .............................: 2
Chip number per channel : ....................: 1
Chip layers : ................................: 2
Number of logical units : ....................: 1
Number of chip storage blocks : ..............: 0x592
Number of pages per storage block : ..........: 0x600
Page size : ..................................: 0x4000
Maximum retry level : ........................: 0x0
Load relocation block table : ................: Fail
Load CP list......
CP list data is not found in HDD, use the default CP list!
Load CP list... : ............................: success
Read password information...
Read password information : ..................: Fail
Author:  saltwater [ September 4th, 2024, 4:25 ]
Without relocation block table, and correct CP list, how can you create translator?
I think not at all
I have a same case, and after load loader, i have a same result.
Author:  mhp666 [ September 4th, 2024, 10:41 ]
Hi, I still have the same problem and I just updated to the new version.
As soon as I find out something I will post it in this thread.
http://www.phpbb.com/
