 Post subject: Kingston USB Stick with PS2251-13-Q
PostPosted: July 27th, 2024, 8:31
i got this USB Stick from a customer, with just broken USB connection, all pads are there, new USB connector set perfect.
and it still does not work.
there are 2x emmc connected to PS2251 - so i would say, i can't read them through reader.
V1 and V2 is 1,8 and 3,45V - looks legit to me :D
any idea what else could be damaged? - maybe when connector broke there was a short? thermal camera tells me controller starts up, emmcs are getting voltage - everything in normal temp area 35-45 degrees.
 Post subject: Re: Kingston USB Stick with PS2251-13-Q
PostPosted: July 27th, 2024, 14:48
Be careful. Not all USB 3.0 connectors have the same pinout.
https://forum.hddguru.com/viewtopic.php?f=10&t=36891&p=260036#p260036
Also, is R02 (zero-ohm link) grounded?
PostPosted: July 28th, 2024, 3:20
thx - yes both Zero ohms are grounded.
i first tried of course with original Connector, and behaviour is exactly the same. it goes to 0,07-0,1A - when i try to read ID via PC3k Portable - it goes up to 0,15A and just show me some Kingston info in ID field - but no serial/size and so on.
PostPosted: July 28th, 2024, 4:55
A quick google shows it to be a problematic combo. Think I'd start by either breaking the voltage to the emmc or pulling the chips to prove the controller.
PostPosted: July 29th, 2024, 15:03
PS CPU with EMMC ,Is it original Kingston ?
PostPosted: July 30th, 2024, 14:07
Phison_MPALL_v5.13.0C - GetInfo.exe.
PostPosted: August 1st, 2024, 5:45
Yes this PS2251-13-Q is used in secure / encrypted USB Flash drive with EMMC chips.
Here more info: https://www.cl.cam.ac.uk/~sps32/HWIO_IRONKEY.pdf
PostPosted: August 1st, 2024, 6:19
Case has been solved. Problem with soldering of those chips. And it was encrypted by Datatraveler Vault.
odzyskiwanie danych
PostPosted: August 2nd, 2024, 4:35
Melvin Sir ,
You Did This Case Finally ? .What tool did you use for this brother .
PostPosted: August 2nd, 2024, 6:38
You Did This Case Finally?
yes
Hotair + microscope + flux + tin + tweezers + soldering iron + Windows + DMDE
odzyskiwanie danych
PostPosted: August 2nd, 2024, 12:17
yes
Well,
i was referring to fe,vnr or flash .In this case none were used thanks for info
PostPosted: August 7th, 2024, 14:23
yep - Melvin helped out :D due holiday ;)
Users browsing this forum: gold6565 and 25 guests
