 Post subject: SSD Not Working Properly. Showing Only 1 MB
PostPosted: September 8th, 2024, 7:19
Hello There,
I have one ssd Model Number ZEB-SD26 Sata 2.5". It comes with no power. When I check than i found that 2 capesitor and 6 pin voltage regulator damage which i mark in the image. I have same donor ssd and change the faulty parts. when i plugged it to computer, in device manager ssd showing "REALTEK_RL6643 an in disc management it show only 1 MB. Data is important. seeking help from your side. I haven't any MRT, PC3000 like tools.
Thanks In Advance.
 Post subject: Re: SSD Not Working Properly. Showing Only 1 MB
PostPosted: September 8th, 2024, 9:16
It's in safe mode - check you have voltage to the nand.
PostPosted: September 8th, 2024, 10:02
How to check power supply to nand?
PostPosted: September 8th, 2024, 10:03
No it is not in safe mode
PostPosted: September 8th, 2024, 13:51
@fzabkar can you help me please? You have wide experience in this.
PostPosted: September 8th, 2024, 14:40
Measure the voltages at the inductors.
PostPosted: September 8th, 2024, 16:51
No?
PostPosted: September 9th, 2024, 2:48
Yes, it is.
PostPosted: September 9th, 2024, 3:12
@fzabkar all inductor voltage is 3.3v
PostPosted: September 9th, 2024, 3:13
@northwind sir
How to recover data id it is in safe mode?
PostPosted: September 9th, 2024, 12:41
That makes no sense.
PostPosted: September 10th, 2024, 6:05
Thank you all to help me. But customer is in hurry. Return back ssd to customer.
