SSD Not Working Properly. Showing Only 1 MB
http://forum.hddguru.com/viewtopic.php?f=10&t=44648
Author:  kagzizaid80 [ September 8th, 2024, 7:19 ]
Post subject:  SSD Not Working Properly. Showing Only 1 MB
Hello There,
I have one ssd Model Number ZEB-SD26 Sata 2.5". It comes with no power. When I check than i found that 2 capesitor and 6 pin voltage regulator damage which i mark in the image. I have same donor ssd and change the faulty parts. when i plugged it to computer, in device manager ssd showing "REALTEK_RL6643 an in disc management it show only 1 MB. Data is important. seeking help from your side. I haven't any MRT, PC3000 like tools.
Thanks In Advance.
Author:  Lardman [ September 8th, 2024, 9:16 ]
Post subject:  Re: SSD Not Working Properly. Showing Only 1 MB
It's in safe mode - check you have voltage to the nand.
Author:  kagzizaid80 [ September 8th, 2024, 10:02 ]
How to check power supply to nand?
Author:  kagzizaid80 [ September 8th, 2024, 10:03 ]
No it is not in safe mode
Author:  kagzizaid80 [ September 8th, 2024, 13:51 ]
@fzabkar can you help me please? You have wide experience in this.
Author:  fzabkar [ September 8th, 2024, 14:40 ]
Measure the voltages at the inductors.
Author:  Arch Stanton [ September 8th, 2024, 16:51 ]
No?
Author:  northwind [ September 9th, 2024, 2:48 ]
Yes, it is.
Author:  kagzizaid80 [ September 9th, 2024, 3:12 ]
@fzabkar all inductor voltage is 3.3v
Author:  kagzizaid80 [ September 9th, 2024, 3:13 ]
@northwind sir
How to recover data id it is in safe mode?
Author:  fzabkar [ September 9th, 2024, 12:41 ]
That makes no sense.
Author:  kagzizaid80 [ September 10th, 2024, 6:05 ]
Thank you all to help me. But customer is in hurry. Return back ssd to customer.
