HDD GURU FORUMS
http://forum.hddguru.com/
Sandisk BGA315
http://forum.hddguru.com/viewtopic.php?f=10&t=44757
Page 1 of 1
Author:  einstein9 [ October 19th, 2024, 5:17 ]
Post subject:  Sandisk BGA315
Hello guys,,
Anyone have an idea if there is a way to read this nand?
Full dump i mean..
BGA315
Thnx
Author:  aekhv [ October 19th, 2024, 6:06 ]
Post subject:  Re: Sandisk BGA315
I've no idea how to read it, but I heard also this SanDisk uses LDPC ECC and adaptive XOR... So data recovery may be a really pain in *ss.
Author:  Lardman [ October 19th, 2024, 6:37 ]
BGA315 to BGA100 adapter ?
Author:  einstein9 [ October 20th, 2024, 2:02 ]
Totally Diff.
Author:  okton [ October 20th, 2024, 13:28 ]
Is there a controller on the other side of PCB or is it a FLASH with integrated USB controller?
Author:  csava [ October 20th, 2024, 19:40 ]
I did some research on it, but currently I can only read 1CE/1LUN. This type of flash memory typically contains multiple LUNs. However, I cannot find the second physical CE. Changing the address range doesn't help either. So I can only read 1/2 or 1/4 of the chip's capacity.
Author:  einstein9 [ October 21st, 2024, 1:38 ]
@csava Thnx for the info.
PM sent :idea:
http://www.phpbb.com/
