HDD GURU FORUMS
http://forum.hddguru.com/
Pinout for Sandisk 453E99B37A6B00
http://forum.hddguru.com/viewtopic.php?f=10&t=44769
Page 1 of 1
Author:  bos [ October 23rd, 2024, 6:07 ]
Post subject:  Pinout for Sandisk 453E99B37A6B00
256GB M.2-drive, SM2258XT and Sandisk 453E99B37A6B00. Controller has probably encrypted the NAND so I do not want to desolder it as first step, but still I'd like to take a look at the contents.
Since there is one free footprint (only one NAND on PCB), is there a possibility to solder some points on a monolith-adapter and access the NAND? According to this link it is BGA304/BGA272. I do not have an adapter for that and I do not find the pinout in ONFI-specifications. In VNR it says "Custom pinout" for this chip.
So how do I find the pinout so I can hook it up to a monolith adapter and try to read the contents?
Author:  arvika [ October 23rd, 2024, 6:26 ]
Post subject:  Re: Pinout for Sandisk 453E99B37A6B00
It use BGA-272 pinout. You will find it at ONFI document.
Author:  bos [ October 23rd, 2024, 6:35 ]
ONFI BGA-272 does not match the pinout. BGA-316 is close, but still no exact match.
Or maybe I'm reading the document wrong. Gray areas = N/C?
Author:  arvika [ October 23rd, 2024, 7:32 ]
Your chip in fact it is BGA-304. But from my notes it have compatible pinout with BGA-272. But of course verify me, I can be wrong.
Author:  bos [ October 23rd, 2024, 7:34 ]
@arvika: I sent you a mail because I decided this one is a bit out of our league.
http://www.phpbb.com/
