| Anybody know the order of chips in this device? http://forum.hddguru.com/viewtopic.php?f=10&t=44791 |
Page 1 of 1 |
| Author: | HaQue [ October 30th, 2024, 22:55 ] |
| Post subject: | Re: Anybody know the order of chips in this device? |
hi, it is normally like this: Attachment: 6645-PCBF-ChipOrder.jpg [ 171.54 KiB | Viewed 11425 times ] But of course could be different for a number of factors such as design is modified from a 2 flash version, or firmware dev didn't care. |
| Author: | Zero Alpha [ October 30th, 2024, 22:56 ] |
Is that one of those DIY ssd boards? |
| Author: | Kodi Green [ October 31st, 2024, 8:21 ] | |||
| Post subject: | Re: Anybody know the order of chips in this device? | |||
Zero Alpha wrote: Is that one of those DIY ssd boards? I didn't understand the question, what do you mean? HaQue wrote: hi, it is normally like this: Attachment: The attachment 6645-PCBF-ChipOrder.jpg is no longer available But of course could be different for a number of factors such as design is modified from a 2 flash version, or firmware dev didn't care. Thanks I will try to transplant the memories to another functional SSD
| Author: | arvika [ October 31st, 2024, 9:44 ] |
Use 100% same PCB. Not other one. |
| Author: | fzabkar [ October 31st, 2024, 20:52 ] |
Kodi Green wrote: I will try to transplant the memories to another functional SSD Why??? Is the controller faulty? If not, then you're just torturing the drive. |
| Author: | Kodi Green [ November 1st, 2024, 9:25 ] | ||
arvika wrote: Use 100% same PCB. Not other one. Where can I get a similar one? I searched the web and couldn't find anything. fzabkar wrote: Kodi Green wrote: I will try to transplant the memories to another functional SSD Why??? Is the controller faulty? If not, then you're just torturing the drive. Most of the components are damaged, I transferred the controller to another SSD, it gets too hot
| Author: | fzabkar [ November 1st, 2024, 15:01 ] |
This looks like the result of an overvoltage on the 5V supply. This typically happens when the user swaps dissimilar SATA cables between different PSUs. If this is the case, then the capacitors are unlikely to fail. I would remove all the DC-DC converter ICs and then test for shorts between each inductor and ground. If there is a short, then one or more of the major ICs will have failed. There would be no point in transplanting a dead NAND. If there is no short, I would replace the DC-DC converters. |
| Author: | arvika [ November 1st, 2024, 16:37 ] |
Nands are usually armored, but of course better check before all the work. |
| Author: | fzabkar [ November 2nd, 2024, 2:36 ] |
I saw a similar disaster at Tom's Hardware. The SDRAM was shorted, but the NANDs survived. The user replaced all 3 DC-DC converters and the SDRAM. He also replaced the controller, but I don't think that was necessary (he did this before he posted). |
| Author: | Kodi Green [ November 7th, 2024, 10:49 ] | ||||
| Post subject: | Re: Anybody know the order of chips in this device? | ||||
fzabkar wrote: I saw a similar disaster at Tom's Hardware. The SDRAM was shorted, but the NANDs survived. The user replaced all 3 DC-DC converters and the SDRAM. He also replaced the controller, but I don't think that was necessary (he did this before he posted). How I can replace this components? or find a compatible one When removing the controller, the capacitors that were around it are no longer short-circuited (I measure using the red tip of the tester on ground and the other tip I test that the capacitors do not give 0 on both sides) Around this integrated component in the image the capacitors are shorted
| Author: | fzabkar [ November 8th, 2024, 5:51 ] |
I've just started to have a look at your converter ICs. I haven't been able to identify the "CDEA" IC, but the following photos of similar boards have "CX7HA" and "CXAKA" in its place. https://i2.kknews.cc/-DVtTWEStxIrTfeFWWUrA_-bn82da_5ovjJjHk4/0.jpg https://img2.quasarzone.com/editor/2023/02/22/aec9fe47c455f0e23b428c98a0d8dd4e.jpg SY8035DBC, Silergy, High Efficiency, 2.7 - 5.5Vin, 5A, 1MHz Synchronous Step Down Regulator, marking CXxyz, DFN3×3-10: https://web.archive.org/web/20190913190402/www.szyucan.com/upfile/IC-PDF/SY8035.pdf These are two compatible ICs: https://www.sun-flytech.com/images/pdf/2020060353c84.pdf (MT3033) https://hmsemi.com/downfile/HM3450D.PDF (HM3450D) |
| Author: | fzabkar [ November 9th, 2024, 18:35 ] |
S2xyz can be either an SOT23-5 or SOT23-6 IC (pin #5 of the 6-pin package is not used). It appears to be either an APS2420ATBER (5-pin) or RS3402 (6-pin). Suitable substitutes appear to be SY8009AAAC, SY8009BABC, JW5222SOTB, JW5222SOTA. This thread identifies the pinout: https://vlab.su/viewtopic.php?f=49&t=132789 Quote: SOT23-6 (1-EN 2-GND 3-SW 4-IN 5-PG 6-FB) References from my research: APS2420ATBER, Chipown, Synchronous buck regulator, 1MHz,2.0A, 2.5V - 6.5Vin, marking S2xyp, SOT-23-5L: https://datasheet.lcsc.com/szlcsc/Wuxi-Chipown-Micro-electronics-APS2420ATBER_C130331.pdf SY8009AAAC, Silergy, Synchronous Step Down Regulator, 1.5MHz, 1.5A, 3V - 5.5V in, marking ADxyz, SOT23-5: https://www.olimex.com/Products/Breadboarding/BB-PWR-8009/resources/SY8009.pdf https://www.skytech.ir/DownLoad/File/6482_SY8009%20(1).PDF SY8009BABC, Silergy, Synchronous Step Down Regulator, 1MHz, 2.0A, 3V - 5.5V in, marking CUxyz, SOT23-6: https://www.olimex.com/Products/Breadboarding/BB-PWR-8009/resources/SY8009.pdf https://www.skytech.ir/DownLoad/File/6482_SY8009%20(1).PDF https://ae-pic-a1.aliexpress-media.com/kf/H8673ad6a38df4982a249fc3e3361bf34p/Sm2258xt-SSD-Solid-State-Drive-Main-Control-Board-circuit-Board-Circuit-Board-DIY-Nesting-4-Stickers.jpg JW5222SOTB, JoulWatt, Synchronous Step-Down Converter, 2.5A, 2.5V - 6V, 1MHz, marking JWAUx, SOT23-6: https://www.skytech.ir/DownLoad/File/11208_JW5222.pdf JW5222SOTA, JoulWatt, Synchronous Step-Down Converter, 2.5A, 2.5V - 6V, 1MHz, marking JWB6x, SOT23-5: https://www.skytech.ir/DownLoad/File/11208_JW5222.pdf https://cdn.staticneo.com/a/neo-forza-nfs10-480gb/07.jpg https://avatars.dzeninfra.ru/get-zen_doc/2380919/pub_5ef4a2613a77242b38c071e8_5ef4a447a5460d486a97f047/scale_2400 (SOT23-6, marking S2Yxx) https://www.aliexpress.com/item/1005006947648697.html (RS3402 S2Y**, described as SOT23-5 but pictured as SOT23-6) https://www.ruten.com.tw/item/show?22109005222443 (RS3402 SY8089 package SOT23-5) https://taoic.oss-cn-hangzhou.aliyuncs.com/134/134-4ed30cb1-4117-11ec-bb98-00163e1552d4.jpg (shipping package, RS3402, SOT-23-6L, CHIPOWER) https://www.mydigit.cn/forum.php?mod=viewthread&tid=419065 (RS3402, marking S2G / S2BJB) https://www.mydigit.cn/forum.php?mod=viewthread&tid=406976 (S2BJB) |
