HDD GURU FORUMS
http://forum.hddguru.com/
SSD eraser question
http://forum.hddguru.com/viewtopic.php?f=10&t=44924
Page 1 of 1
Author:  athena [ December 8th, 2024, 8:13 ]
Post subject:  SSD eraser question
Hi
I have got a work of secure eraser work of 100 odd ssd's
Unlike CMR hard disks there is no chances of remnant data recovery on defect lists with SSD.
I would like to know is it technically ok to single pass overwrite., so that I can quote for the same.
Thank you.
Author:  Arch Stanton [ December 8th, 2024, 8:43 ]
Post subject:  Re: SSD eraser question
Single pass overwrite potentially leaves you with overprovisioned space. Writing zeros potentially leaves you with lots of unaffected data due to advanced firmware detecting zeros and simply add place-holders in FTL. Zero filling overwriting virtually nothing due to firmware level compression. Why not use built-in secure erase, crypto erase etc.?
Author:  athena [ December 8th, 2024, 11:17 ]
Thanks a lot Joep
Do I need third party tools or manufacturer utility
to initiate secure eraser.
Cusomer wants reports of each eraser like model, fw, sn, erasing date / time
Technique used and time required etc.
Author:  Arch Stanton [ December 8th, 2024, 15:44 ]
Maybe a tool like KillDisk will make your life easier but I personally believe your client wants to purchase peace of mind with that certificate.
Author:  athena [ December 12th, 2024, 1:06 ]
Exactly ,even client suggested this.
Is there any universal secure /crypto erase tool irrespective of make of SSD ? For large volume of disks its not practical to check each ssd & erase it using manufacturer supplied tools (not all tools are self bootable as well)
Author:  fzabkar [ December 12th, 2024, 1:33 ]
IIRC, the ATA standard has sanitize and cryptoerase commands. These are universal, ie not vendor specific.
Author:  athena [ December 14th, 2024, 6:50 ]
Thanks a lot fzabkar , I have used killdisk as I think its too clumsy to boot large (different types ) of laptops using linux & issue commands onsite.
There should be a readymade live bootable pen drive having interface , logging to perform the same. Besides that I read that not all models support secure erase.
Author:  Amarbir[CDR-Labs] [ December 17th, 2024, 2:53 ]
Well,
Older versions of killdisk was able to work with several hard drives without a license
Author:  athena [ December 17th, 2024, 10:56 ]
Well,
Thanks do you know any commercial software solution which implements secure eraser
Author:  Amarbir[CDR-Labs] [ December 17th, 2024, 11:49 ]
Well,
Well,
i use only killdisk ver 10.2.7 and thats about it i also have a commercial Cyber forensic tool hardware that i use just for erasing
http://www.phpbb.com/
