 Post subject: Camera decides to write photos broken to memory card midway
PostPosted: January 9th, 2025, 13:59
hello everyone and happy new year!
This happens in the same camera and same day, same memory card. Photos taken from 11:00 to 15:00 and from 19:00 to 23:00 are fine. Photos that was shot between 15:00 and 19:00 either won't open at all, or heavily broken.
I took the image of the memory card through gddrescue and ran DMDE on it, no luck.
Any DIY methods or any software that I can buy?
the card is ExFAT Sandisk ultra 128gb
 Post subject: Re: Camera decides to write photos broken to memory card mid
PostPosted: January 9th, 2025, 15:51
Can you share one of the broken images?
PostPosted: January 9th, 2025, 15:54
sure, here https://we.tl/t-03RmRMfyW5
PostPosted: January 9th, 2025, 16:26
I can see two thumbnails for two different photos. Arch Stanton is our resident expert.
PostPosted: January 10th, 2025, 18:02
File is a mess, contains 4 JPEG starts.
So you want software to do what exactly? Were they recovered FS based or signature based?
PostPosted: January 10th, 2025, 21:23
If you decode all parts, you get a mess too ..
PostPosted: January 11th, 2025, 3:53
both FS and signature. actually I tried recovery hoping that it would find them, I knew that this has nothing to do with file recovery and no recovery needed because files written to card like this
PostPosted: January 11th, 2025, 3:54
if I send you the image file and the broken files can you give me quote on this? do you think that this is doable?
PostPosted: January 11th, 2025, 5:36
So these files were found like this on a memory card? Have you tried with Klennet Carver?
PostPosted: January 12th, 2025, 9:20
- yes those files were like this on the memory card
- I tried klennet carver after seeing your message yesterday, I always wanted to try that. wow, that software tortured my pc real good. It found some missing photos intact but there still some photos missing, do you that this the last thing that can be done in this case?
PostPosted: January 13th, 2025, 4:06
Yeah, it's resource hungry ..
Yeah, I am afraid so ..
Users browsing this forum: No registered users and 28 guests
