| WD Green 240Gb SATA MCU issue http://forum.hddguru.com/viewtopic.php?f=10&t=44986 |
Page 1 of 1 |
| Author: | melvin [ January 5th, 2025, 6:53 ] |
| Post subject: | Re: WD Green 240Gb SATA MCU issue |
If NAND isn't dead yet there is a chance. It needs to be checked if there's no other shortage that causes the heat. Glue can be cut and controller removed. Last resort would be NAND transfer to identical PCB. |
| Author: | terminator2 [ January 5th, 2025, 11:47 ] |
melvin wrote: If NAND isn't dead yet there is a chance. It needs to be checked if there's no other shortage that causes the heat. Glue can be cut and controller removed. Last resort would be NAND transfer to identical PCB. Thanks melvin I will give it a try , where is this SSD specific FW & encryption information stored , Is MCU has role to decide only wear levelling ? |
| Author: | terminator2 [ January 14th, 2025, 9:24 ] |
melvin wrote: If NAND isn't dead yet there is a chance. It needs to be checked if there's no other shortage that causes the heat. Glue can be cut and controller removed. Last resort would be NAND transfer to identical PCB. Hi Transplanting Nand will not solve this issue as MCU encryption is there. If MCU cannot be removed then what will be alternate.What Guru's like Arvika would have done ? |
| Author: | melvin [ January 14th, 2025, 16:29 ] |
terminator2 wrote: MCU encryption is there. Doubt it, but you can always check with a donor. Also checking PCB should be done again. We still don't know for shure if it's MCU's fault or any other component is shorted. |
| Author: | arvika [ January 14th, 2025, 19:24 ] |
I made many test with this model, so far not found good solution, but I do not give up. |
| Author: | terminator2 [ January 16th, 2025, 3:23 ] |
melvin wrote: terminator2 wrote: MCU encryption is there. Doubt it, but you can always check with a donor. Also checking PCB should be done again. We still don't know for shure if it's MCU's fault or any other component is shorted. Thanks , Yes MCU might not be short , supporting components might be faulty . |
| Author: | terminator2 [ January 16th, 2025, 3:24 ] |
arvika wrote: I made many test with this model, so far not found good solution, but I do not give up. Oh Thanks , Its tough case indeed. Glue on MCU might prevent chip reading . |
| Author: | athena [ January 19th, 2025, 11:06 ] |
If Arvika Says its so difficult then possibly no one in the world including ace might be able to recover data from this SSD. |
