 Post subject: kingdton datatraveller usb 3.0 128gb parameters for pc3000
PostPosted: April 28th, 2025, 14:04
i got the USB3.0 drive and it has 2 flash chips each 64 GB - tsop48
the driver chip is 6137 SSS
the 2 flash chip has on them 115T150G-3S-1S
i put the chip in the pc3000 flash tsop48 reader and it is not recognizing the flash memory
can someone help me get the right flash parameters so i can add this to the PC3000 Flash to complete the case
thank you Larry
 Post subject: Re: kingdton datatraveller usb 3.0 128gb parameters for pc30
PostPosted: April 28th, 2025, 20:17
this one could be a Toshiba or refurbished NAND, but I don't know what chip based on the marking you posted. is there any other marking like HVKLFJL or similar? Does PC3K give a flash ID?
also take a look here
https://flash-extractor.com/forum/viewtopic.php?p=63625
Users browsing this forum: No registered users and 144 guests
