Help identifying burnt out chips on ssd (probably dc-dc?)
http://forum.hddguru.com/viewtopic.php?f=10&t=45134
Author:  eugene_black [ February 20th, 2025, 14:53 ]
Post subject:  Help identifying burnt out chips on ssd (probably dc-dc?)
Hi
I have three apacer panther SSDs and two of them have burnt out components which I struggle to identify. Here are pictures of the component from all three SSDs. They have different marking but have the same placement and function so I assume they are interchangeable.
Author:  fzabkar [ February 20th, 2025, 16:00 ]
Post subject:  Re: Help identifying burnt out chips on ssd (probably dc-dc?
From my notes ...
SY8003A1/SY8003A1DFC, Silergy, Step Down Regulator, 2.5V - 5.5Vin, marking rDxyz, DFN-8:
https://us1.silergy.com/download/downloadFile?id=3767&type=product&ftype=note
https://ae01.alicdn.com/kf/S958f55d27fd34281b3c460ba52a97737j.jpg
G5728BT11U, Global Mixed-mode Technology, 1.4MHz, 1A, Synchronous Step-Down Regulator, 2.5V - 6Vin, marking 578Bx, SOT23-5: (= TLV62568DBV)
http://www.gmt.com.tw/product/datasheet/EDS-5728B_5728C.pdf
https://web.archive.org/web/20190214204301/http://www.gmt.com.tw/product/datasheet/EDS-5728B_5728C.pdf
Author:  eugene_black [ February 21st, 2025, 4:14 ]
From my notes ...
That's it, thank you a lot!!
Author:  eugene_black [ February 22nd, 2025, 7:17 ]
From my notes ...[/url]
Do you have also some info about the diode that stands on the power line? It is pretty small so it is a bit confusing for me
Author:  fzabkar [ February 22nd, 2025, 12:48 ]
Maybe this?
DFLT6V0A, Diodes Inc, 6.0V, marking FAG, 225W, TVS diode:
http://www.diodes.com/_files/datasheets/ds30581.pdf
Author:  fzabkar [ February 22nd, 2025, 13:12 ]
Very disorganised, with a lot of duplication ...
https://web.archive.org/web/20230522144629/http://www.users.on.net/~fzabkar/Datasheets/DATAURLS.HTM
https://web.archive.org/web/20230522144629/http://www.users.on.net/~fzabkar/Datasheets/datasheets.txt
https://www.hddoracle.com/viewtopic.php?f=100&t=1577
