 Post subject: Came across a cool video recovering data from NVME SSDs
PostPosted: March 3rd, 2025, 2:36
Hi everyone
Today i came across a pretty cool youtube channel from China. This guy is recovering data from SSD devices
At the end of this video he did some kind of external power soldering. I am very curious of what he did in this video. Can anybody explain or better have a method on doing so??
Here is the video. External power soldering method at 4:44
https://youtu.be/uaKWK5IH7xc?si=S6PRc8c3pRS8pFsE
Many thanks!
 Post subject: Re: Came across a cool video recovering data from NVME SSDs
PostPosted: March 3rd, 2025, 6:26
I try apply expternal power to one SSD some time ago which give bad reading. In theory: you can controll external power value to adjust reading quality.
In practice: it not help. Result was 100% same.
I'm not say idea is wrong, I test on one case only. It could be many factors which decide on final result.
PS. On youtube video everything works perfect always ;)
PostPosted: March 3rd, 2025, 16:44
That's a clever idea. Instead of removing and replacing a faulty PMIC, he's using a PMIC from an identical donor and hardwiring its outputs into the patient. An alternative approach would be to hardwire one or more DC-DC converter modules, but then you would have a potential problem with power-up sequencing.
Years ago I had the same idea to power up the MCU on a WD PCB where the SMOOTH IC was burnt. That is, use the voltages from a donor PCB to power up the patient MCU and then read its embedded ROM via terminal. The problem is that one would need to ensure that the POK signal was set, but I don't know which pin this is. This could also cause problems with those PMICs that have Power_Good outputs which are sensed by the controller, or those PMICs with an I2C bus that communicates with the controller.
BTW, here is the "embedded" URL, if you want to avoid Youtube's fluff:
https://www.youtube.com/embed/uaKWK5IH7xc
I've been watching his other videos. There's a lot of good stuff there, although I don't agree with some of his methods.
This is the RSS feed for his Youtube channel:
https://www.youtube.com/feeds/videos.xml?channel_id=UCrHVBycuv9_EUQmHQOEotQA
Users browsing this forum: No registered users and 29 guests
