 Post subject: in need of specific MPtool
PostPosted: April 9th, 2025, 6:41
hello everyone please if someone have this version of MPtool
SMI SM2259XT2 MPTool FIMN48 W0309A FWW0302B0 its available in usbdev but can't donwload it .. it tell me file is offline
 Post subject: Re: in need of specific MPtool
PostPosted: April 9th, 2025, 16:41
Best Regards......
SM2259XT2_FIMN48_PKGW0309A_FWW0302B0.7z [1.36 MiB]
Downloaded 1138 times
PostPosted: April 10th, 2025, 8:07
i got error Flash connectivity test fail (22)/(08.12)
this is smi flash id output
Drive: 2(USB)
Model: KINGSTON SA400S37/240G
Fw : W0302B0
Size : 228936 MB [240.1 GB]
From smart : [SMI2259XT] [W0302B0 00] [N48R0]
Controller : SM2259XA bufferless
FlashID: 0x2c,0xd3,0xc,0x32,0xea,0x30,0x0,0x0 - Micron 176L(N48R) QLC 1024Gb/CE 1024Gb/die
Channel: 2
CE : 1
TotDie : 2
Plane : 2
Die/Ce : 1
Ch map : 0x03
CE map : 0x01
Inter. : 1
First Fblock : 4
Total Fblock : 1620
Total Hblock : 3578
Fblock Per Ce : 1620
Fblock Per Die: 1620
Original Spare Block Count : 96
Vendor Marked Bad Block : 0
Bad Block From Pretest : 74
Press any key to exit or Space to open full text report
Please share reports as text, not a sreenshot!
did i do anything wrong ?
PostPosted: April 13th, 2025, 7:37
anyone can guide me with this please
PostPosted: April 13th, 2025, 12:56
The error Flash connectivity test fail (22)/(08.12) means the tool failed during a flash connectivity test — essentially, it tries to communicate with the NAND dies through the controller’s internal channels and CEs (Chip Enables), and at some point it didn’t get the expected response.
Relevant bits from your report:
Controller: SM2259XA bufferless
FlashID: 0x2c,0xd3,0x0c,0x32,0xea,0x30,0x0,0x0 — Micron 176L QLC
CE: 1, Channel: 2, TotDie: 2
Bad Block From Pretest: 74
Original Spare Block Count: 96
Possible reasons for the failure:
High bad block count:
You already have 74 bad blocks before any operation. That’s quite a lot for a 240GB QLC drive. On QLC NAND (especially Micron 176L), a higher bad block rate can cause issues in connectivity or read/write mapping.
Incorrect or incomplete flash mapping table (FEMU config) for this specific NAND
If the firmware or flash map config you’re working with doesn’t fully support this NAND or has mapping assumptions not matching your CE/chip/die layout, connectivity tests can fail.
Controller quirks — SM2259XA bufferless is somewhat finicky
This variant sometimes behaves differently in factory tools versus older SMI tools. Connectivity test patterns may expect specific CE toggling patterns or plane interleaves.
What you can check/do:
Verify the FEMU / mapping table you’re using matches this NAND config
1 CE
2 Planes
1024Gb per Die
Some factory tools expect 2 or 4 CEs for similar capacity, and if misconfigured, a connectivity test will fail.
Check if your flash config file (if using one) has the correct Flash ID entry for 0x2cd30c32ea30
(you might be using a config with 64L or 96L assumptions instead of 176L QLC)
Try bypassing the connectivity test if possible in your tool
Some versions of SMI tools allow continuing even if that test fails, though of course it may cause problems later if the issue is deeper.
Double-check your NAND’s physical soldering or connection (if DIY modded)
Intermittent connections or CE line issues could trigger connectivity failures, though less likely if you didn’t rework the drive.
PostPosted: April 13th, 2025, 13:03
Can you make a short video with the steps you take up to the error message?
PostPosted: April 14th, 2025, 9:51
Is this tool for SSD repair only or data recovery? how it work ? I try to detect ssd with my sata port but it is unable to show device?
Users browsing this forum: Google [Bot] and 15 guests
