Page 1 of 1
Patriot Transporter Lite 2TB - Power Cycles=Unsafe Shutdowns
Posted: May 10th, 2025, 13:14
by michal.ochedowski
Hello.
I have a new external SSD Patriot Transporter Lite 2TB. When I first connected it to my laptop, in CrystalDiskInfo I noticed that Power Cycles value was 4 and Unsafe Shutdowns value was also 4. I figured that it was probably after the product have been tested in the factory.
A little bit later both of these values have risen to 9. Each time I properly closed the Windows 10 OS. There were no pending or ongoing operations regarding this SSD. There were no power failures. I did everything correctly. I'm a bit concerned though. These two values seem to increase after each shutdown. I'm worried that I'm shortening the lifespan of the drive. What if I need to use the warranty for another unrelated reason and the company will blame it on me and on Unsafe Shutdown SMART parameter.
Any thoughts?
Re: Patriot Transporter Lite 2TB - Power Cycles=Unsafe Shutd
Posted: May 12th, 2025, 3:37
by northwind
Let me guess, you have an LGA 1700 motherboard.
Posted: May 12th, 2025, 3:53
northwind wrote:Let me guess, you have an LGA 1700 motherboard.
I have an old model of Asus laptop. I think that the motherboard you've mentioned is dedicated for a desktop pc.
Yesterday I wrote to Patriot. Perhaps they will shed some light on the matter. There is another issue with Transporter Lite, because each power on cycle is counted twice.
Posted: May 13th, 2025, 1:00
I've just received a message from Patriot. They strongly recommend using "Safely Remove Hardware and Eject Media" option every time before shutting down the computer. Doing so shouldn't increase the "Unsafe Shutdowns" parameter. Well, I won't be able to test this solution, because the drive went back to the store. It might however be a useful tip for someone with the similar problem.
I also have to give credit to the manufacturer. They promptly responded to my every question.
Posted: May 14th, 2025, 3:59
by northwind
Right, but I doubt "Unsafe Shutdowns" is only affected by safe remove & ejects.
It remains to be seen.
I believe it's a relatively new SMART parameter, to me it's not important and it's related to unhandled buffer.
Posted: May 14th, 2025, 15:53
by fzabkar
See section 7.6.2 for an explanation of what happens on the host side during shutdown.
NVM Express Revision 1.3 May 1, 2017:
https://nvmexpress.org/wp-content/uploads/NVM_Express_Revision_1.3.pdf
Unsafe Shutdowns: Contains the number of unsafe shutdowns. This count is incremented when a shutdown notification (CC.SHN) is not received prior to loss of power.
