 Post subject: Test Stand SM2258XT
PostPosted: May 20th, 2025, 11:40
hello,
I bought 2 tests pcb with a SM2258XT as controller and differents supports for BGA.
I'm waiting answer from the vendor about hardware but I saw on the black card, a header pins with tdi/tdo/tck.... so I guess a jtag.
is someone already use, with success, one of these cards? did you use JTAG and if yes, it is only to communicate with controller or were you able to read a flash?
I'm free to chat about this subject !
 Post subject: Re: Test Stand SM2258XT
PostPosted: May 23rd, 2025, 0:19
Thats cool. Do they work?
Zero Alpha: zeroalpha.com.au
PostPosted: May 25th, 2025, 6:00
hello,
not really. I tested with several flashs but result is not as expected, it is why I would like to see with jtag :)
PostPosted: May 27th, 2025, 21:47
Your generally restricted to nand that the SM2258XT supports. Then you will need the SM2258XT MPTool to program it. https://www.usbdev.ru/files/smi/sm2258xtmptool/
