Has someone been successful with this SAMSUNG SSD
http://forum.hddguru.com/viewtopic.php?f=10&t=45407
Author:  higgsboson [ June 18th, 2025, 6:35 ]
Post subject:  Has someone been successful with this SAMSUNG SSD
Guys
Has anyone been able to crack this MCU , portable doesn't support it.
SSD is detected with lower capacity .
Model No -Samsung MZ-VL25120
Author:  SOSdonnees [ June 19th, 2025, 9:07 ]
Post subject:  Re: Has someone been successful with this SAMSUNG SSD
Have you considered reflowing the chips, especially the NAND ones?
Author:  higgsboson [ June 19th, 2025, 9:21 ]
No considering delicate electronics & pcb , actually SSD is getting detected as 1 GB.Do you think Heating Nand with hot air might work?
Thanks for suggestion.
Author:  Arch Stanton [ June 20th, 2025, 15:50 ]
Might. As it isn't able to load firmware from NAND (the 1 GB capacity is typical), one option is that NAND is 'detached'. But can also be simply firmware corrupt, same symptom, and without PC3000 support not a lot you can do.
Author:  arvika [ June 22nd, 2025, 2:02 ]
IMHO reflow/reballing make things only worse. 99% cases not help.
Author:  higgsboson [ June 24th, 2025, 6:42 ]
Thanks arvika
your words are like Digital masters final judgements
I was sure this might not be issue related to electronics.Your post has came at right time :good:
