Intenso UFD - NAND package?
http://forum.hddguru.com/viewtopic.php?f=10&t=45469
Author:  martyjelen [ July 11th, 2025, 3:48 ]
Post subject:  Intenso UFD - NAND package?
Hello, could someone help me with identifying this chip? What package is this?
https://ibb.co/JWSrjFm7
https://ibb.co/MkRc9jKm
I wonder if it's possible to determine pinout for this chip. There is a place for standard TSOP48 package. So, when I measure continuity from TSOP48 pads to those pads 3x10 I should find which ones are connected. Am I right or totally wrong?
Thank you for help.
Author:  Gregory [ July 11th, 2025, 5:43 ]
Post subject:  Re: Intenso UFD - NAND package?
Yes, this is standard 3x10 UFD Sandisk pinout, you can find it in VNR and PC3K database, you can also do measure continuity from TSOP48.
Author:  martyjelen [ July 11th, 2025, 5:58 ]
Thank you for reply Gregory.
So, here are my measurements.
https://ibb.co/Z1XhM0q9
https://ibb.co/qM062qSj
Is this correct?
Author:  martyjelen [ July 11th, 2025, 6:12 ]
It looks like monolith number 0153 from VNR database.
Author:  Gregory [ July 11th, 2025, 7:13 ]
Exactly this is it, ofc you measured on the PCB so you have a mirror image of the pinout :)
Author:  martyjelen [ July 11th, 2025, 7:34 ]
Yep, I know. Thank you very much.
Author:  martyjelen [ July 15th, 2025, 5:36 ]
I soldered it to monolith universal adapter but can't read ID in VNR. Maybe it's a waste of time with this capacity. It's 256 GB device. So I don't think there is a solution in VNR database.
Author:  arvika [ July 16th, 2025, 1:41 ]
Most flash don't have solution. You need try develop.
