from where can i order this component?
http://forum.hddguru.com/viewtopic.php?f=10&t=45586
Author:  freelancerx1 [ August 30th, 2025, 8:51 ]
Post subject:  from where can i order this component?
hello guys. from where i can find and order this?
Author:  fzabkar [ August 30th, 2025, 10:07 ]
Post subject:  Re: from where can i order this component?
MP5016, Monolithic Power, 2.7 - 15V, 0.7 - 5A, Current Limit Switch with Over-Voltage Clamp and Reverse Blocking, marking EK, QFN10:
https://www.monolithicpower.com/pub/media/document/MP5016_r1.0.pdf
Farnell and Mouser stock this part. If you just want to recover your data, you can bypass this component by bridging the input and output.
https://www.hddoracle.com/viewtopic.php?f=100&t=1615
Author:  freelancerx1 [ August 31st, 2025, 4:08 ]
thank you fzabkar you are the one
