| Crucial MX500 1TB not detected http://forum.hddguru.com/viewtopic.php?f=10&t=45680 |
Page 1 of 1 |
| Author: | cbkhoo1492006 [ October 18th, 2025, 8:56 ] |
| Post subject: | Crucial MX500 1TB not detected |
Hi all, I have an Crucial MX500 1TB that suddenly becoming not detectable by BIOS after laptop (BSOD) crashed during Windows update. Model: Crucial MX500 1TB M.2 SATA NGFF Brought date: 20200926 Health (last known 2025/03/20): 96 % SMART shows drive as healthy Controller: SM2258H DRAM: D9SHD X 2 (MT41K256M16TW-107:P) Nand: NW913 X 8 (MT29F1T08EMHAFJ4-3R:A) Attachment: Attachment: Troubleshooting NAND chip numbering as follow:
- Back (B) (Bottom) side (without controller) - First NAND is beside DRAM with forth (last) beside test. Using Easytools with test pin (ROM mode) shorted manage to forced the drive to ROM mode. From Easytools tab (Read flash ID) address location (Raw):
- But 00000060 and 000000A0 first column device ID is not identified (00 FF FF FF FF FF 00 00). Attachment:
File comment: Device ID with all NAND soldered 1_SSD_fail_Top_3.png [ 493.33 KiB | Viewed 1080 times ] - By trying NAND removal procedure, it has been found that NAND chip (T no. 3) to be the culprit.
- Removing good NAND chip should cause additional four device ID not identified that would be 6 in total. - Removing NAND chip (T no. 3), four device ID is not identified has appeared on (00000040 and 00000080) second column alongside (0000060 and 000000A0) first column. Attachment:
File comment: Device ID with faulty NAND (T no. 3) removed 2_SSD_fail_Top_3_removed.png [ 488.48 KiB | Viewed 1080 times ] - By swapping (T no. 3 and T no. 4) NAND chip location has also shifted not identified device ID from (00000060 and 000000A0) first column to becoming second column. This shows chip is the culprit and not solder joint/pad. Attachment:
File comment: Device ID with NAND (T no. 3 & T no. 4) swapped 3_SSD_fail_Top_3&4_Swap.png [ 542.44 KiB | Viewed 1080 times ] According to https://support.rusolut.com/portal/en/kb/articles/reading-bga132-152 - BGA132/152 chips has 2 data lines with 4 CE (Crystal) for each data lines respectively. From here, it is possible one of the two data line of NAND chip becoming not detectable due to NAND chip write wear out? It is possible to recover it or to recover the data? Thanks. |
| Author: | cbkhoo1492006 [ October 18th, 2025, 11:35 ] |
| Post subject: | Re: Crucial MX500 1TB not detected |
cbkhoo1492006 wrote: Attachment: 0_1_Front.jpg Attachment: 0_2_Back.jpg Troubleshooting NAND chip numbering as follow:
- Back (B) (Bottom) side (without controller) - First NAND is beside DRAM with forth (last) beside test. From the picture taken, Top side third NAND (T no. 3) has been removed. |
