Page 1 of 1
TeamGroup SSD Power Failure – No Visible Damage
Posted: December 11th, 2025, 5:51
by sosrecup
I'm receiving a growing number of TeamGroup SSD drives that
fail to power on completely:- No power-on response with or without PCB shorting
- No behavior change when applying controlled heating
- No visible signs of burning or physical damage on the board
- The drives remain entirely unresponsive under all standard diagnostic procedures
Could you please advise on known causes for this issue or recommended next steps for diagnosis and recovery?
Thank you in advance.
Lamine
Re: TeamGroup SSD Power Failure – No Visible Damage
Posted: December 11th, 2025, 6:43
by pepe
check the 0 ohm resistor (fuse)
Posted: December 11th, 2025, 10:01
by sosrecup
Dear @pepe
Thank you for your reply.
Are you talking about this one?
Kind regards
Lamine
Posted: December 11th, 2025, 10:08
by fzabkar
Measure the voltages at the 3 inductors.
Posted: December 11th, 2025, 11:04
by sosrecup
Dear @fzabkar
Could you please help repair them on the card?
Thank you for your support.
Posted: December 11th, 2025, 11:06
by fzabkar
by pepe
yes, that one.
Check if it is open, if so, check if the 'bottom' end is shorted to gnd.
Posted: December 21st, 2025, 11:19
by sosrecup
pepe wrote:yes, that one.
This resistor shows 0.5 Ohm
fzabkar wrote:Measure the voltages at the 3 inductors.
The 3 inductors also show about 0.4 Ohm - 0.5 Ohm
Where could the problem be?
Thank you for your help
Lamine
Posted: December 21st, 2025, 14:40
by fzabkar
Sorry, I can't help you.
Posted: December 21st, 2025, 17:31
by sosrecup
fzabkar wrote:Sorry, I can't help you.
Does this mean that the problem is elsewhere?
Posted: December 21st, 2025, 22:19
by fzabkar
The problem is that you don't understand what is required.
