| Samsung 970 Evo Plus 500GB no power http://forum.hddguru.com/viewtopic.php?f=10&t=45930 |
Page 1 of 1 |
| Author: | gameboybin [ March 15th, 2026, 12:29 ] |
| Post subject: | Samsung 970 Evo Plus 500GB no power |
I got this 970 Evo plus Samsung NVME SSD Attachment: Screenshot 2026-03-15 232347.png [ 60.59 KiB | Viewed 2301 times ] Attachment: I have measured some capacitors. None of them gives any voltages Upon Heat inspection the only chip that have a slight temperature is this AtAYF chip Attachment: IRI_20260316_020146.jpg [ 252.8 KiB | Viewed 2301 times ] Attachment: VIS_20260316_020146.jpg [ 68.73 KiB | Viewed 2301 times ] Attachment: The drive consuming 0.1A Thanks for helping me out! |
| Author: | fzabkar [ March 15th, 2026, 14:08 ] |
| Post subject: | Re: Samsung 970 Evo Plus 500GB no power |
"AtAYF" is an e-fuse. There should be 3.3V at Vin and Vout. https://www.hddoracle.com/viewtopic.php?p=8872#p8872 I expect that its pinout would be similar to STEF05: https://www.hddoracle.com/download/file.php?id=3096&mode=view |
| Author: | fzabkar [ March 15th, 2026, 15:59 ] |
fzabkar wrote: I expect that its pinout would be similar to STEF05: Perhaps it's similar to STEF4S rather than STEF05. |
| Author: | gameboybin [ March 21st, 2026, 7:13 ] |
So i managed to fix the drive. The problem was the Power IC S2FPS05A01. After swapping the chip. The drive started working again |
