 Post subject: HFM512 GDJTNI-82A0A problem
PostPosted: June 26th, 2026, 9:46
This HFM512 GDJTNI-82A0A NVMe disk comes from a laptop that was damaged by splitting Coca Cola. The laptop is not working now so I was thinking about the rescueing data with help of external eclosure. My NVMe enclosure AXAGON uses JMS 583, so it could be OK,( if it is not a fake chip) because Windows reports it as
USB\VID_152D&PID_0562&REV_0214
which is JMS567 (or JMS562) SATA 6Gb/s Bridge Controller
The result is the windows can not recognise SSD disk in that enclosure.
The disk is quite hot in the enclosure eventhough
I did not find any oxidation on PCB of SSD.
What voltages should I measure on SSD disk?
Do you have any idea how to continue?
Thank you for help
L.
 Post subject: Re: HFM512 GDJTNI-82A0A problem
PostPosted: June 26th, 2026, 10:07
Can you just physically check if it's a 583, 562, or 567 controller? Because if it's one of the latter, this drive won't work.
You must use a USB adapter that supports the PCIe protocol.
PostPosted: June 26th, 2026, 11:30
Physically ( on PCB) there is JMS 583 IC
PostPosted: June 26th, 2026, 11:31
Do other working NVMe drives work with this adapter?
PostPosted: June 26th, 2026, 12:26
Yes, in the past it did
PostPosted: June 27th, 2026, 17:07
Is it correct to suppose I should find only these voltages:
3.3V
1.8V
and about 1.2V
Or must be there any other voltages present?
PostPosted: June 27th, 2026, 17:34
What voltages do you measure at the 3 inductors to the left of the main IC?
https://au.static.webuy.com/product_images/Computing/Solid%20State%20Drives%20-%20NVMe/SSSDHKHHFM512GDJTNIA_l.jpg
https://notebookparts.com/cdn/shop/products/HFM512GDJTNG-8310A_L15195-002__51069.1612982947.1280.1280.jpg
PostPosted: June 29th, 2026, 5:19
On 3 inductors (those near voltage regulators) I measured:
1,8V
0,896V
2,56V
From the last value I guess there is a short somewhere
I also enclosed a picture taken with infra camera. As you can see there is a short in ( or below ) UFS memory.
Do you think reballing could help?
Or any other solutions?
Thanks for reply
PostPosted: June 29th, 2026, 6:22
They all seem OK to me.
PostPosted: June 29th, 2026, 6:35
John1 wrote:
2,56V
No, this is the correct value.
No, the drive is electronically functional. The controller heats up, but within normal operating ranges.
Everything points to firmware corruption. The only options are to heat/cool the NAND flash drive.
For me too.
PostPosted: June 29th, 2026, 8:02
But 2.56V seems to me low. Normally, there should be about 3.3V. Or not?
Besides if you check the infrared picture in details, you will see the memory is not warm in all parts the same but only one part is more hot. So from that, I guess, there is an internal short. Or can you please explain why I am wrong?
Can you explain more? Thanks
PostPosted: June 29th, 2026, 8:31
The correct power supply for this memory is between 2.6 and 2.8V.
Only the controller heats up, not the entire system, because programming has cut off access to the memory, and therefore its full initialization.
Part 5 and 6:
https://blog.acelab.eu.com/methods-of-d ... ction.html
PostPosted: June 29th, 2026, 13:04
It would not make sense for the output of a DC-DC converter to be 3.3V if its input is 3.3V.
Users browsing this forum: No registered users and 30 guests
