| Maxio MAP1202A NVMe, TRIM fully applied, all LBAs zero — any http://forum.hddguru.com/viewtopic.php?f=10&t=45982 |
Page 1 of 1 |
| Author: | qzwn521@gmail.com [ April 13th, 2026, 23:49 ] |
| Post subject: | Maxio MAP1202A NVMe, TRIM fully applied, all LBAs zero — any |
Hello everyone, I would like to ask whether anyone here has seen any recovery progress for Maxio MAP1202A NVMe SSDs, especially in cases where TRIM has already fully taken effect. My case: - SSD: ZhiTai TiPlus5000 1TB - Interface: NVMe M.2 - Controller: Maxio MAP1202A - Failure type: accidental file deletion only, no physical damage - Current state: the drive is still detected normally and is not hardware-failed - Important detail: TRIM was fully applied, and now all user LBAs read back as zero So this is not a typical logical recovery case anymore. Regular software recovery is obviously useless at this point. From what I understand, the only possible chance would be vendor-specific / controller-level work, such as entering technical mode and restoring older translator/mapping data, if that is even supported for this controller family. What I want to know is: 1. Has anyone here seen successful recovery research or practical progress for MAP1202A in this exact “deleted + TRIM fully applied + LBAs = 0” scenario? 2. Is ACE Lab / PC-3000 SSD known to be actively working on MAP1202A NVMe support, or is there still no real development status publicly known? 3. Has any lab already submitted sample drives to ACE or other developers for this controller? 4. Even a rough status would help: not started / under research / engineering samples received / technical mode partially working / translator recovery being tested I am not asking for consumer software suggestions, because TRIM has already fully taken effect and the data area now reads as zeros. I am specifically trying to understand whether there is any real engineering progress or expected roadmap for this Maxio NVMe controller family. Any firsthand information from labs, engineers, or people who have seen internal testing would be very appreciated. Thank you. |
