CRUCIAL BX500 1TB - Wrong Capacity 1.07 GB
Posted: April 15th, 2026, 15:05
by grevan
OK, so i have this drive, BX500 1000GB (CT1000BX500SSD1) not allways recognized but managed to "see" it with DMDE and Opensuperclone with wrong capacity 1.07GB and name "SM2259AB-10-10000000", in BIOS also the controller name. So most likely a controller fault, but i was just wondering if someone could check the voltage readings just to see if that part is ok, it seems ok.
*** Is the white smd near the 5V connector (5 and 0) a capacitor?
Thanks guys.
Re: CRUCIAL BX500 1TB - Wrong Capacity 1.07 GB
Posted: April 15th, 2026, 15:35
by grevan
Posted: April 15th, 2026, 17:48
by fzabkar
Although I don't have a reference for comparison, those voltages look OK to me. Those two small DBGA-4 ICs at the left of the crystal appear to be 3.3V and 1.8V LDO regulators. You might want to check that.
Posted: April 15th, 2026, 18:23
by grevan
What do you think is that white component (5v and 0v)? Looks like a fuse, but i bet is a capacitor. Have two more right at the crystal.
Posted: April 15th, 2026, 18:45
by fzabkar
It must be a capacitor.
I think the SOT23-5 component (R9xxx) might be this:
https://www.diodes.com/datasheet/download/AP331A.pdf
Posted: April 16th, 2026, 14:42
by grevan
Those 3.3V and 1.8V LDO regulators are good.
Thank you for your attention.
Posted: July 13th, 2026, 13:50
by Hardcore Games
Given this is an intermittent problem it might be wise to find a new SSD before this BX500 croaks
Low cost USB boxes can host the BX500 for file recovery
