Samsung 840 Pro 512GB - MZ-7PD512
Posted: May 3rd, 2026, 11:38
by Win95
I believe my SSD is stuck in BSY State.
Its old but very little use - <1 year with little read/writes.
Tried power cycle trick - no change. (plug SATA Power only - ON for 60 mins, OFF for 60 seconds, ON for 60 mins)
Using systemrescue USB on different laptop w/ SATA-USB
sudo hdparm -I /dev/sdb
/dev/sdb:
sudo smartctl -a /dev/sdb
Read Device Identity failed: scsi error device will be ready soon
Using systemrescue USB on same PC via SATA
ata5: link is slow to respond, please be patient (ready=0)
ata5: hardreset failed
ata5: reset failed, giving up
I read that I can short two pins to enter SAFE/TECHNICAL mode - https://www2.futureware.at/~philipp/ssd ... Manual.pdf
Is data recovery without PC-3000 possible?
I would be willing to pay in advance for DIY Solutions, Ideally trying to avoid sending off to a Data Lab
Re: Samsung 840 Pro 512GB - MZ-7PD512
Posted: May 4th, 2026, 8:41
by Win95
some other members - @ivo.andonov - seemed to have fixed this specific drive by changing / re-soldering the RT9991
https://forum.hddguru.com/viewtopic.php ... 36#p314636
Ive also read it could be the internal fuse.
I am planning to check these parts when my Multimeter arrives, and possibly change them.
Does anybody else have any ideas? - Data Recover in the UK is now around £550 for this task
Posted: May 6th, 2026, 17:36
by Lardman
Win95 wrote:Does anybody else have any ideas? - Data Recover in the UK is now around £550 for this task
Not it's not.... It's half that.
