Kingston NV2 NVME stopped working
March 21st, 2026, 7:21
I have this Kingston NV2 Drive that stopped working. Upon inspections. It only has 0.1A. Nothing on the board gets hot. I measured all capacitors. None of them are shorted. So it must be something with those power ICs
Can anyone help me with the voltage datasheet of them. Many thanks!
Re: Kingston NV2 NVME stopped working
March 21st, 2026, 11:18
G5409AS1U, Global Mixed Mode Tech, load switch, 7A, 0.5V - 5.5V input, marking 5409, AQFN2X2-12:
https://product.dzsc.com/product/753656-2022316145143282.html
https://web.archive.org/web/20250702041049/https://product.dzsc.com/product/753656-2022316145143282.html
SY8061IDEC, Silergy, Single Output Step Down (Buck) Converter, 2.5V - 5.5Vin, 1A, 1.5MHz, marking rQxyz, DFN2×2-6:
https://forum.diacom.az/viewtopic.php?t=382
http://saemitech.com/default/img/yeogi/img/sub03_pdf01.pdf
http://www.series-tech.com/upload/20220715103755.pdf
https://blog.csdn.net/icgogo/article/details/155054869 (blog)
https://i-blog.csdnimg.cn/direct/5816ee65b27e41cdbc6536cd4849ee67.png (app circuit)
5K0 / 5KO is a step-down converter. Measure the voltages between inductor and ground. That's the output.
May 3rd, 2026, 12:39
Well, after all measurements, swapping nands, and other things. It came out that the Nands Are dead. that was sad
