| 1TB 2230 NVME only recognized as 1MB - Need MPTool http://forum.hddguru.com/viewtopic.php?f=10&t=46068 |
Page 1 of 1 |
| Author: | bluejay3246 [ June 4th, 2026, 17:46 ] |
| Post subject: | 1TB 2230 NVME only recognized as 1MB - Need MPTool |
Looking for PS5019-E19 (E19T) MPTool / factory package for SSSTC XA1-311024 I have a SSSTC XA1-311024 1TB M.2 2230 SSD that is not working. No data recovery needed, just want to use it again. * Model: SSSTC XA1-311024 * PN: M1106370-007 * PCB: XA1-311024 REV 21 * Controller: Phison PS5019-E19-35 * NAND: SK hynix H25BFT8G5M3R-BDJ Current symptoms: * Enumerates as NVMe normally * PCI Vendor 1987 (Phison) * Firmware reported as EJRM01.2 * Windows detects disk as "PCIe SSD" * Serial number present * Capacity reported as exactly 1,048,576 bytes (1 MB) * Disk appears Online/Healthy but RAW * Flash ID utility shows 0 MB and cannot obtain NAND information * SMART/reliability counters mostly blank PowerShell reports: FirmwareVersion : EJRM01.2 Size : 1048576 BusType : NVMe I already found an E19 firmware BIN named EJF10002_05082021.BIN, but it appears to be from a different firmware family than EJRM01.2, so I am not willing to flash it blindly. I am specifically looking for: * PS5019-E19 / E19T MPTool * EJRM01.2 factory package * SSSTC XA1-311024 manufacturing package * Matching config / parameter files for H25BFT8G5M3R NAND Has anyone recovered a 1 MB-capacity PS5019 drive in this state, or does anyone know which MPTool branch supports EJRM firmware? |
| Author: | Agrail [ June 8th, 2026, 5:27 ] |
| Post subject: | Re: 1TB 2230 NVME only recognized as 1MB - Need MPTool |
EJRM01.2 is a masked ROM version. This state usually indicates a physical malfunction, such as a malfunctioning memory chip controller, etc. Such a drive is likely unrepairable without additional physical intervention. Use the phison nvme flash id utility from VLO to obtain more detailed information about the chips map and its manufacturer. |
| Author: | bluejay3246 [ June 8th, 2026, 10:47 ] |
Thank you for the info. This is what the utility showed when connected to nvme slot on the mobo: v0.386a OS: 10.0 build 26200 Drive : 0(NVME) Driver : W10(0:3) Model : Fw : Size : 0 MB [0.0 GB] LBA Size: 1 CEL not supported |
| Author: | Agrail [ June 9th, 2026, 5:48 ] |
At least the controller type should be detected. There seems to be a driver issue here. Try connecting the drive via an NVMe-to-USB adapter. |
| Author: | bluejay3246 [ June 9th, 2026, 9:48 ] |
This is what is shown in an enclosure: v0.386a OS: 10.0 build 26200 Drive : 1(USB) Bridge : JMS Model : PCIe SSD Fw : EJRM01.2 Size : 1 MB [0.0 GB] LBA Size: 512 CEL not supported |
| Author: | Agrail [ June 10th, 2026, 6:05 ] |
You should use Phison nvme flash id, not Phison nvme flash id 2. http://vlo.name:3000/ssdtool/ |
| Author: | bluejay3246 [ June 10th, 2026, 10:23 ] |
Enclosure: v0.3a OS: 10.0 build 26200 Drive : 1(USB) Bridge : JMS Model : PCIe SSD Fw : EJRM01.2 Size : 1 MB [0.0 GB] LBA Size : 512 Controller: PS5019-E19 in Rom Mode FlashID : 0xad,0x5e,0x2a,0x33,0x0,0xa0,0xad,0x5e [0x0f 0x00 0x02 0x02] - Hynix 3dv5-96L TLC 16k 2048Gb/CE 512Gb/die Bank00: 0x5e,0x2a,0x33,0x0,0xa0,0xad,0x5e - Bank01: 0x5e,0x2a,0x33,0x0,0xa0,0xad,0x5e - Bank02: 0x5e,0x2a,0x33,0x0,0xa0,0xad,0x5e - Bank03: 0x5e,0x2a,0x33,0x0,0xa0,0xad,0x5e - List of banks possible incorrect |
| Author: | bluejay3246 [ June 12th, 2026, 14:16 ] |
I am reading from online help that Flash ID v1 reports PS5019-E19 in ROM Mode and successfully reads Hynix 3dv5-96L TLC NAND IDs on all banks. Does this indicate a missing/corrupted firmware configuration and would a PS5019 MPTool rebuild be the appropriate next step? If so, how to obtain it? |
| Author: | Hardcore Games [ June 12th, 2026, 16:19 ] |
I suggest getting a new SSD instead of fighting this corpse of a SSD |
| Author: | bluejay3246 [ June 12th, 2026, 16:22 ] |
I have other ssds and data recovery isn't a problem. Trying to bring this back to life |
| Author: | chasemdev [ July 7th, 2026, 22:46 ] |
I am in the exact same situation as you, created an account just to follow up haha. Did you happen to get any resolution? I have a XBOX Series S I'm repairing, the SSD is not detectable at all, seems to be marked as 1MB, and the Xbox's CPU's are locked to the SSD, so I need to recover the 1st partition on this SSD in order to fix the XBOX. There is no alternative. SSSTC XA1-31512, PN M1106374-007 Phison PS5019-E19-35 controller SK hynix H25BFT8F5M3R NAND Firmware currently reports EJRM01.2 From what I'm reading, I kinda wondered if I could simply flash a firmware upgrade onto the chip, to attempt to repair. :-/ |
| Author: | bluejay3246 [ July 7th, 2026, 22:55 ] |
No. People stopped helping |
| Author: | Agrail [ July 8th, 2026, 5:16 ] |
chasemdev, Take this drive to data recovery engineers, or you'll ruin it completely. The first thing MPTool does when flashing a drive is destroy the data. bluejay3246, I don't have a drive with these chips and don't have compatible firmware, so I can't really offer any advice. But the SSD itself is acting strange. The chip IDs are offset by 1 byte. This might be normal, but I doubt it. Most likely, there's something wrong with the controller. |
