Help for recovering USB drive with IS903 controller
Posted: July 20th, 2026, 16:47
by KdMK1973
Hi Guys, I am trying to recover a 128GB memory USB-drive with a IS903 controller. The controller does not seem to work properly. the memory chip is labled "43010Y018946 128G" or "4301DY013346 128G" or something similar, but it appears to be relabeled.
Can anybody help in recoverring the data from the memory chip?
Thanks and best regards
kdMK1973
ChipGenius does say about the memory chip:
Description: [K:]USB-Massenspeichergerät(NAND Flash)
Device Type: Mass Storage Device
Protocal Version: USB 3.00
Current Speed: High Speed
Max Current: 304mA
USB Device ID: VID = 1F75 PID = 0903
Serial Number: 16110956000040
Device Name: USB DISK
Device Revision: 0001
Product Model: NAND Flash
Product Revision: 1.00
Controller Vendor: Innostor
Controller Part-Number: IS903-A4 - ??ROM??
Flash ID code: 453E87937E57 - SanDisk SDTNQFDMA-064G - 2CE/Single Channel [MLC-16K] -> Total Capacity = 128GB
Tools on web:
Possible Flash Part-Number
[1CE]SDTNQFDMA-064G x 2 pcs/Channel x 1 Channel
Flash ID mapping table
[Channel 0] [Channel 1]
453E87937E57 --------
Re: Help for recovering USB drive with IS903 controller
Posted: July 21st, 2026, 2:54
by arvika
Yes. Chip-off method should give good result for this controller.
Posted: July 21st, 2026, 15:36
by KdMK1973
Thanks for you advice. I assume that this means physically detaching the memory chip and try to read out by means of an other controller? Can you recommend somebody who has the knowhow and tool for this? Thanks a lot and best regards
Martin
Posted: July 22nd, 2026, 2:52
by arvika
Yes. desolder the chips, read and recover data bypassing the controller.
Tools ljke FE, VNR, PC3K, NFT. Me and many others on this forum can do this.
Posted: July 22nd, 2026, 5:36
by Arch Stanton
KdMK1973 wrote:The controller does not seem to work properly.
Seems to be in ROM mode. Prolly not the controller itself then but NAND or inability to talk to NAND.
The person who answered you is one of the best and located in Poland (easy to ship the flash drive there: https://odzyskiwanie-danych.com.pl/
Posted: July 22nd, 2026, 15:44
by KdMK1973
arvika wrote:Yes. desolder the chips, read and recover data bypassing the controller.
Hi Arvika, thanks for your answer. Do you offer such services? An other user wrote so. Can you give me a idea about the costs?
Martin
Posted: July 23rd, 2026, 0:18
by arvika
Yes. Write PM.
