Joined: April 9th, 2026, 0:03 Posts: 33 Location: china
Ver3.26.8.26 1、Added dynamic XOR algorithm for SM3265 series 2、Added layout and sector sorting algorithm for one Samsung TF card; LDPC check algorithm is undertesting 3、Added ADDE14A7reread command for hynix_v7 4、Added models: SM3281_89C40832A600_2x4_by Beast IS918_2CA4E554A900_1x2_by Csava join pagebefore operation IS918_983E980376E4_1x1_by fxc unknow‑TF_453E98B3766B_1x1_by mfz 5、Added layouts: Innostor(IS) IS918v2 1126x16 Monolith unknow‑TF 1146x16 SamSung MicroSDv1 36+2272x8 JMicron(JM) JmSDv3 1142x16
Ver3.26.8.17 1、Fixed an issue whereswitching layout would cause shear‑byte step errors when shear‑byte steps werepresent 2、Added CBM sector sorting algorithm 3、Added automatic bad‑byte shearing 4、Added models: PS2251‑19_AD89285300B0_2x1_by mfz SM3281_AD7E285302B0_2x1_by Aday SG7081_AD5C282A0190_1x1_by fxc 5、Added layouts: IS918 1144+1136x15 SM3265v2 1138x16+32 SM3265v2 1140x16+32 SG1581/7081 1150x7+1158 CBM2399 1152x16
Ver3.26.8.10 1、Fixed the issue where data read errors occurred when ECC correction was disabled. 2、Optimized LDPC correction speed, achieving approximately 2‑fold performance improvement. 3、Added models: PS2251‑09_453C98B376E3_1x4 SM3281_AD5E283300A0_1x2 CBM‑TF_ECDE88BF90C6_1x1 PS2251‑11_983C98B376E3_1x1_ldpc SM‑TF_453E98B3766B_1x1 SM3265P_89D40C32AA00_1x1_by czj SM3281_2CC40832A2002x1_by 900 4、Added layouts: SM‑TFv3 1142x16+32+32 UP309v2 1138x16 FC3379 1162+1146x15 SM3271 1136x8+31 CBM2199v2 1115x8 CBM2199v2 1103x16
Ver3.26.7.23 1、Added function toset partition start offset after opening image 2、Added LDPC ECCsupport for PS2251-11 1144x16 and YS9082 (2304+2308)x4 3、Fixed issue whereediting and cutting bytes/bits failed to take effect with multiple dump 4、Added the following models: SM3265_45489803766C_1x1_by900 FC3379_453E9803766C_1x2_byfxc RAW IS918_EC5E981F84C2_2x1_byAday AU89103_453E9803766C_1x4_byCsava BGA304 IS918_983C98B376E3_2x1_byfxc SM2236_2C84643CA900_1x4_byCsava SM3281_2C2CD31C32C600_1x4_byCsava SM3281_2CA40832A100_1x1_byBeast PS2251-19_983E98B376E3_2x1_byCsava 1FF0 L=0x0C JmSD_AD7E285302B0_1x1_byfxc IS918_2CD31C32C600_1x1_byCsava HG2319v4_EC5E981F84C2_1x1_byCsava 0FF0 L=0x0C IS918SN_983E9803766B_2x1_Sectornumber IS918SN_983E9803766B_1x1_Sectornumber SM3265_98489803766C_1x2_by900 SM3265_AD7E280B00C0_1x2 AS-TF_AD5E283300A0_1x2_byfxc SM-SD_EC3A94C3A4CA_1x4_byfxc AU89103_89C40832A600_1x4_2banksmodify SN_Slow 5、Added Layout: SG1581/7081v21150x15+1158 SM3265v3 1158x16+32 SM-TFv2 1148x16+32x2 IS918v6 1152x16 CBM2199v3 1144x16 AU8910 1146x16 SM3271 638x26+32 CBM-TF 1152x16 PS2251-11 1144x16 YS9082 (2304+2308)x4
