Samsung T9 1TB
Posted: September 28th, 2026, 22:26
by grtcm
Hi, I’m just a regular user and don’t have professional data recovery or electronics experience.
I have a Samsung T9 1TB (MU-PG1T0B) with password protection enabled. It was working normally before, but now it no longer unlocks properly.
The original Samsung Portable SSD Software can distinguish between correct and incorrect passwords. Wrong passwords show an error, while the correct password is accepted.
However, after entering the correct password, the main data partition never appears. Windows shows the drive as Offline, and after turn it back online, still only the small ~73 MB Samsung security partition remains visible.
I tested it on two different Windows PCs, including Windows 10 and Windows 11, with the same result. I also tried a Mac.
I have not formatted, reset, erased, or repartitioned the drive.
Has anyone seen this kind of T7/T9 unlock failure before? Is there any non-destructive way to recover access to the encrypted data?
Thanks.
Re: Samsung T9 1TB
Posted: September 29th, 2026, 3:45
by fzabkar
Re: Samsung T9 1TB
Posted: September 29th, 2026, 18:13
by grtcm
Thanks. Here is the SMART information and the DMDE Partitions tab.
Re: Samsung T9 1TB
Posted: September 29th, 2026, 18:17
by grtcm
Re: Samsung T9 1TB
Posted: September 30th, 2026, 9:37
by fzabkar
Available Spare is down to 95% (= 0x5F), so the drive has already begun to degrade.
As for the 1TB partition, it appears to have disappeared from the partition table in sector 0, unless it is some quirk of Samsung's encryption. I would use DMDE to examine sectors 0 and 149504. Use Tools -> Copy Sectors to copy these sectors to a destination file on another drive.
Re: Samsung T9 1TB
Posted: September 30th, 2026, 10:28
by grtcm
Thanks. I checked both sectors with DMDE.
Sector 0 contains a valid MBR with the ~76.5 MB FAT security partition, and 149504 is completely zero-filled.
Since the T9 is still locked, I suspect this may be Samsung’s encrypted/locked view rather than the actual underlying data.
I can also attach the two 512-byte sector dumps if useful.
Re: Samsung T9 1TB
Posted: September 30th, 2026, 21:26
by fzabkar
I don't know anything about these drives. How do you normally unlock it? Do you launch some tool inside the FAT partition, and does this tool set up a password challenge?
Re: Samsung T9 1TB
Posted: October 1st, 2026, 2:29
by grtcm
Yes. Normally, when the T9 is locked, Windows only exposes the small ~76.5 MB partition containing Samsung’s Portable SSD Software.
I launch the Samsung tool from that partition, enter the password, and the software sends the unlock request to the drive. I don’t know the exact challenge/authentication protocol used internally.
In my case, the correct password is accepted, but instead of the full volume appearing, the disk becomes Offline and remains in the locked/restricted layout.
Re: Samsung T9 1TB
Posted: October 1st, 2026, 9:45
by fzabkar
In DMDE, if you check Advanced Mode and drag the vertical scrollbar from top to bottom, do you see anything other than zeros?
If you run a read benchmark in HD Tune, do you see a discontinuity between the two partitions? I'm wondering whether the drive is just serving up zeros instead of reading the actual data. You may need to experiment with the stroke setting to see the first partition.
Re: Samsung T9 1TB
Posted: October 2nd, 2026, 2:12
by grtcm
fzabkar wrote:In DMDE, if you check Advanced Mode and drag the vertical scrollbar from top to bottom, do you see anything other than zeros?
I checked further in DMDE Advanced Mode: all sampled LBAs outside the security partition appear to be zero-filled.
As for HD Tune benchmark, the read speed drops sharply near the beginning, then stays relatively flat and stable for the rest of the test.
Re: Samsung T9 1TB
Posted: October 3rd, 2026, 13:00
by grtcm
I checked further in DMDE Advanced Mode, all sampled LBAs outside the security partition appear to be zero-filled. As for HD Tune, the read speed drops sharply near the beginning of each benchmark, then stays relatively flat and stable for the rest of the test.
Re: Samsung T9 1TB
Posted: October 5th, 2026, 21:25
by grtcm
Quick update: after leaving the T9 alone for a few days, I tried it again today and it suddenly unlocked normally.
I still have no idea what caused the fault.
Thanks a lot for your suggestions and help, mate.
