[SOLVED] Crucial BX500 480GB (SM2259XT + B47R) reflashed wit
Posted: October 19th, 2026, 12:42
TL;DR
1. Hardware
2. Symptoms
The drive accepted every write, but everything rolled back after each power cycle.
3. Package used
Default configuration kept: IMB47 profile, auto capacity, Download ISP, Pretest "Reference Original Bad".
Note: the U0312B package for B47R did not detect the drive either with default settings.
4. The problem: MPTool did not detect the drive
With default settings, every port showed "N". Nothing helped: blank drive after Sanitize, drive letter removed, Windows compatibility mode, other AutoPortMapping values.
Reason: by default MPTool uses the "SAT-DMA" transport. It is meant for USB-SATA bridges and does not work on a native AHCI controller.
5. The fix: force the ATA-DMA transport
Changing only PassThroughType was not enough, because the executable chooses its transport afterwards and can override it.
Step 1. In UFD_MP\Setting.set, add these lines under the existing [OPTION] section:
Step 2. In UFD_MP\SMIPortMappingEx.ini, set these keys inside their existing sections. Do not replace the whole file.
Step 3. Close MPTool and open it again as administrator. The status bar now shows "ATA-DMA" instead of "SAT-DMA".
Step 4. Click Scan Drive. Result:
The drive still identified as a normal Crucial. No hardware change was needed.
6. Reflash result
7. Checks after the repair
8. Limitations
9. Warnings
10. SMI Flash ID report (before reflash)
Hope this helps others.
- A Crucial BX500 (SM2259XT + Micron B47R) stuck in a "silent read-only" state was revived with SMI MPTool.
- It worked over a normal motherboard SATA port in AHCI mode: no ROM mode, no pad shorting, no USB adapter.
- The key was forcing MPTool to use the ATA-DMA transport instead of the default SAT-DMA (settings below).
- Also posted on usbdev.ru: https://www.usbdev.ru/f/index.php?topic=14100.0
1. Hardware
- SSD: Crucial BX500 480GB (CT480BX500SSD1), Crucial firmware M6CR052, made in 2021.
- Controller: SM2259XT, DRAM-less.
- NAND: Micron 176-layer B47R TLC, FlashID 2C C3 08 32 EA 30, 8 dies, 4 channels.
- PC: Gigabyte Z790 (Intel 700-series chipset), SATA in AHCI mode, Microsoft storahci driver, Windows 11. This chipset has no IDE mode.
2. Symptoms
- New files disappeared after a reboot.
- Format, Crucial firmware update and Sanitize (Storage Executive) all said "success", then were undone at the next power cycle.
- SMART counters were frozen: the power cycle count never increased, and total LBAs written went backwards.
- SMART said "FAILED - failure expected in less than 24 hours", but no attribute was below its threshold.
- The NAND itself was healthy: 0 reallocated blocks, 0 program/erase failures, 12% wear.
3. Package used
- Code:
SM2259XT(AC)_FIMB47R_PKGU0524A_FWU0524A0
Executable : SM2259XTMPToolU0412A.exe
SWPtest.dll: U0521A_59
Flash DB : U0406 (B47R 2C,C3,08,32,EA,30 is listed)
- Code:
ENABLEPATAPASSTHROUGHUDMA=1
ENABLEUASPMODE=0
ENPIOMODE=0
- Code:
[MapMode]
AutoPortMapping=1
[PortMapping]
SSDMapMode=1
CheckDeviceType=3
SkipSystemDrive=1
SkipRunDrive=1
PassThroughType=2
- Code:
Port 01 : Ready (FW: M6CR052, MB47R)
Capacity : 457862 MB
Serial : 2110E58563B5
Transport: ATA-DMA
6. Reflash result
- Programming ended with "Check ISP Mode fail (7A)".
- But the log showed a successful GPIO check (other BX500 owners on usbdev.ru got "GPIO Check fail (18)/(3C.01)") and firmware writes with matching checksums.
- After a 30-second power cut, the drive booted with the generic firmware U0524A0 (model "SSD", serial AA000000000000001285).
- SMART: PASSED, no errors logged, power cycle count increasing again.
- Persistence: 1 GiB of test files had identical SHA-256 after two power cycles, including 13 hours powered off.
- Full capacity test: 446 files of 1 GiB (445.5 GiB of different random data) written with no errors. After a power cut, all 446 files had identical SHA-256.
- After the test: still 15 bad blocks (the factory ones), 0 program/erase failures, wear evenly spread.
- Speed: about 300 MB/s in the SLC cache, about 70 MB/s when the cache is full (normal for this DRAM-less drive). Read speed about 450 MB/s.
- TRIM works.
8. Limitations
- I did not test whether each of the three Setting.set options, or CheckDeviceType=3, is needed on its own. The full combination is what worked.
- One drive, one platform only (Intel Z790, AHCI, storahci).
- Long-term data retention is not verified yet.
9. Warnings
- MPTool erases everything and permanently replaces the Crucial firmware: no more Storage Executive, no Crucial updates, no warranty. This is not a data recovery method.
- The package must match your NAND exactly. Check it first with SMI Flash ID. A wrong package can brick the drive.
- Keep SkipSystemDrive=1 and check the detected port before clicking Start.
- Code:
v0.5681a
Drive: 0(ATA)
Model: CT480BX500SSD1
Fw : M6CR052
Size : 457862 MB [480.1 GB]
From smart : [SMI2259XT] [T0925A0 00] [B4700]
Controller : SM2259 bufferless
FlashID: 0x2c,0xc3,0x8,0x32,0xea,0x30,0x0,0x0 - Micron 176L(B47R) TLC 512Gb/CE 512Gb/die
Channel: 4
CE : 2
TotDie : 8
Plane : 4
Die/Ce : 1
Ch map : 0x0F
CE map : 0x05
Inter. : 2
First Fblock : 1
Total Fblock : 556
Total Hblock : 7155
Fblock Per Ce : 556
Fblock Per Die: 556
Original Spare Block Count : 44
Vendor Marked Bad Block : 0
Bad Block From Pretest : 15
