Phison E12 NVMe failsafe after power loss: no namespace, R/O
November 16th, 2026, 18:30
Hi all,
Looking for advice on a Phison E12 NVMe in what looks like the classic failsafe / read-only state.
Drive: Greenliant ArmourDrive 960 GB, M.2 2280 NVMe (industrial line), Phison PS5012-E12 (PCI 1987:5012), firmware GECE1BB3 (Greenliant build, not the retail ECFM line).
History: ext4 data drive in an NVIDIA Jetson Orin Nano on a drone, recording camera video at about 120 MB/s. The drone crashed and power was cut mid-write. On the next boot the drive came up in this state.
State now, identical on every power-up, both in the Jetson's M.2 slot and through a JMicron JMS581 USB bridge (smartctl -d sntjmicron):
- Identify OK: correct model, serial and firmware. NVMe 1.3, OACS 0x0017 (no namespace management).
- TNVMCAP 960 GB, UNVMCAP 960 GB: no namespace.
- SMART: Critical Warning 0x09 (spare below threshold, media read-only), Available Spare 0 % (threshold 5 %), temperature stuck at 30 C, Power Cycles 1, Power On Hours 0, all data counters 0.
- Every read to NSID 1 fails with status 0x4016, Invalid Namespace or Format.
Not done: no MPTool, no firmware update, no format / sanitize / namespace creation, no vendor commands. Only identify, SMART / error logs and read attempts. The drive is stored unpowered now.
Questions:
1. Is this the standard E12 translator-loss case for PC-3000 SSD, and is a Greenliant firmware build likely to make it harder?
2. Would anyone with PC-3000 SSD take it as a one-off job for a modest fee? My budget is limited, and I only need one recording session (tens of GB), not the whole drive. I'm in California.
Photos of both sides attached. PCB 96-201-0005A, labels dated 2019-09-24, DRAM SK hynix H5AN4G6NBJR. The NAND package markings aren't legible in my photos; I can take closer ones if needed.
Re: Phison E12 NVMe failsafe after power loss: no namespace,
Today, 6:23
1 - No one will be able to give you an answer remotely, because even if someone else has encountered a similar issue, the memory configuration might be different.
2 - It does not matter whether you need a single file or an entire drive - any potential reconstruction concerns the translator as a whole, rather than just specific parts of it. The amount of data may, but does not necessarily, affect the cost of the recovery servi. Of course, that the issue is indeed caused by firmware damage....
