 Post subject: Samsung PM991 stuck in BSY - any hope?
PostPosted: November 18th, 2026, 17:34
Hi all,
I'm trying to find out whether there is any realistic way to recover data from a Samsung PM991, or whether this case is hopeless.
Drive:
- Samsung PM991 512 GB NVMe M.2 2280, HP OEM (MZVLQ512HALU-000H1, HP PN L85188-002), manufactured 2021
- single BGA package (controller and NAND in one chip)
History:
- died during normal use, PC no longer boots
- not detected in BIOS or OS (not even as 0 GB)
- no BitLocker, no recovery software used, no DIY repair attempts
Findings from a professional lab:
- drive hangs in BSY and does not respond to normal NVMe commands
- responds to technological commands; NAND dump and parts of the service/translator information could be read
- raw NAND data is encoded and AES-encrypted (key bound to the controller), so the dump alone is useless
- attempts to initialize the drive with special procedures failed
- full reflow of the package done, no change
- power supply on the PCB checked and OK
- lab's conclusion: fault in the controller itself, reballing not considered useful
My questions:
1. Is there any tool or known method that can bring a PM991 out of BSY into normal operation (e.g. a loader or a fix of a corrupted service area), so that the controller decrypts the data itself?
2. Has anyone recovered data from this model in a similar state?
3. Or is this realistically the end of the road?
The data is very important and there is no backup, so I'm willing to pay a lab that has a realistic chance with this controller. I'm based in Berlin, Germany.
Thanks for any insight!
 Post subject: Re: Samsung PM991 stuck in BSY - any hope?
PostPosted: Today, 11:01
There is a possibility of recovery, but I recommend that you take it to a professional firm. If this isn't your line of work, don't do anything yourself.
