PEN DRIVE RECOVERY
http://forum.hddguru.com/viewtopic.php?f=10&t=6670
Author:  Rakesh [ February 1st, 2007, 3:55 ]
Post subject:  PEN DRIVE RECOVERY
Can u help me to recover data from a pen drive which is not detected in windows. I opened the drive and found all components (except for main chip) are OK. Can u advice me any device or software for recovery.
Author:  mr2000jp [ March 26th, 2007, 1:35 ]
Post subject:
do you mean the usb flash disk , thats a hard process
Author:  twoshot [ April 21st, 2007, 13:50 ]
Post subject:
Hy
Yuo can try with this tool :
h**p://www.cgsecurity.org/wiki/TestDisk_Download
i had succesfully recovered inacessible 2 GB SD card.
Buona Fortuna :)
Author:  steve67890 [ June 15th, 2007, 19:37 ]
Post subject:  urgentrecovery
download the URGENTRECOVERY Demo. http://www.urgentrecovery.com
good luck
Author:  rchadwick [ June 16th, 2007, 3:32 ]
Post subject:
I don't think these programs will help if the drive isn't recognized.
What someone needs to do is come out with a PC3000-like program for pen drives. Something that has a database of all the common controller chips, and how they arrange data. Then, you could just remove the flash chips, put in a reader, and have the special software decode it, take into account bad blocks, wear leveling, etc...
Author:  Amarbir[CDR-Labs] [ June 16th, 2007, 16:05 ]
Post subject:
Hi Rakesh,
I Am From Chandigarh ,India .Where Are You From .Are You A Recovery Technician or a End User .If You Are a End User Please Do Not Spoil The Drive Beyond Anyones Repair Options .I The Data Imp or Just The Pen Drive Repairs
Author:  sceggy [ July 29th, 2007, 16:10 ]
Post subject:  Re: PEN DRIVE RECOVERY
If main NAND/flash memory semiconductor is shot, your only chance is with an electron microscope, examining charges. However, you may want to look at a EPROM/Flash memory programmer if desperate (however write levelling will be a pain to get around).
scegs
Author:  vsc [ August 7th, 2007, 9:23 ]
If your pendrive is not recognized by windows, almost for sure you have blown up the microfusible on the +5v side.
Check it (seem like a smd resistor but darker, near to the "input pins " of usb drive).
You may bypass it with a thin- 0.2mm- piece off copper.
If not, check the quartz osc -it have to be 12MHz-
Author:  Feklar [ October 24th, 2008, 13:07 ]
In my experience, resoldering the circuit board where the four USB contacts connect to it stands a 70 percent chance of repairing it so the device is recognized. Over time, repeated insertion and removal stresses and eventually microfractures these solder joints, causing a bad electrical connection. Try resoldering those four solder joints. Spooging the joints with soldering rosin first makes it a lot easier and will likely prevent any solder bridge from accidentally forming to short the contacts.
Author:  pcimage [ October 24th, 2008, 14:03 ]
"Spooging"?
Great word!!! :-)
