4Gb SD-Card, reconized but corrupted
http://forum.hddguru.com/viewtopic.php?f=10&t=7766
Author:  mr_spokk [ September 22nd, 2007, 18:50 ]
Post subject:  4Gb SD-Card, reconized but corrupted
Hi there,
I got this SD-Card, it's visible in Windows and it's readable in most DR program.
But I always got corrupted files, except when I use WinHex....then I get some picures look like this:
[img]
[/img]
Always like preview picture, 160x120.
The corupted files is in their original size...2-3mb....but not visible in any program...
I have tried RMP, Stellar Fat/Ntfs, WinHex....
But as I'm a newbee at WinHex, I have only tried the recovery part......not "fiddle around" myself with different solutions.
Any help would be appreciated.
Best Regards
Bosse
Author:  mr_spokk [ September 30th, 2007, 6:56 ]
Post subject:  Re: 4Gb SD-Card, reconized but corrupted
No one have a clue or tip???
Bosse
Author:  mr_spokk [ September 30th, 2007, 9:24 ]
Could sutch a behaviour from the card comes from a bad connection/solderjoint?
Bosse
Author:  dobrevjetser [ September 30th, 2007, 12:45 ]
I think this is very possible, Bosse.
Any other fault would make reading impossible or give complete corruption.
Dobre
Author:  pcimage [ September 30th, 2007, 14:13 ]
I suggest..
Make an image of the card with Winhex.
Remove and reinsert the card
Make another image.
Compare the two.
If there are any differences, then a bad joint is quite possibly the fault.
IMHO of course ;-)
Author:  Amarbir[CDR-Labs] [ September 30th, 2007, 14:14 ]
Soldering try it as they said i have repaired 100 pen drives like this and ram modules too
Author:  mr_spokk [ October 1st, 2007, 15:21 ]
pcimage wrote:
I suggest..
Make another image.
Compare the two.
IMHO of course ;-)
Thanks Sean,
I did try that but there was no difference in the images.
I'm going to talk with the client if it's ok with him that I could it apart and try resolder it.
Will keep you posted on this.
Bosse
Author:  pcparts [ October 3rd, 2007, 21:23 ]
Dear Sir/Maam
Some of the case could be repaired by desoldering
and put memory chips in the adaptor .
We can reorganize data without controller
Data Recovery Training
Myung Information Technology
http://www.mitdr.com
