AVID NAND Flash USB MP3 Player
Posted: February 28th, 2008, 13:46
Greetings
I have a problem with my MP3 Player, few weeks ago when I tried to move few files it "removed itself" from system (I'm using Windows XP Professional). This MP3 Player has ~1GB of storage, so I thought it would be OK if I move 700MB file when 200MB was already on it... bad idea, after above message above sys tray icon the player went in coma. Each time when I plug the device in to USB port, system identifys it correctly but when I try to access it via explore or any other way Windows asks me for a format and immediately unplugs it with an error that it cannot be formated.
I googled a bit and found out that, low level format might be a answer to this problem since person who had same device managed to revive it by doing so. Since I don't have Linux OS and that person was formating that MP3 Flash Player on that System... I used HDD Low Level Format Tool from HDD Guru's website. Too my surprise the software identified My MP3 Flash Player as:
AVID NAND Flash 1.00 [250,6 Mbytes]
Should I give it a try and format the device or I just found a bug in the tool?
Here is system ID for the MP3 Player
