 Post subject: PC3000 flah catastrophic failure
PostPosted: March 8th, 2010, 5:46
hi all
i have recieved my new flash tool from ACE, so far not a successful recovery has been made on any chip as i am experiencing constant catastrophic failures when the chip has been read and the controller has been selected.
have others experienced this?
can this happen due to the wrong controller being chosen?
i have tried contacting ace but have not spoken with them yet so thought i would quickly ask here.
Thank you for any info you can provide.
 Post subject: Re: PC3000 flah catastrophic failure
PostPosted: March 8th, 2010, 6:44
what ashamed, you've just wasted big money.
Ace flash in my opinion is a scam, especially the TS :evil: :evil:
PostPosted: March 8th, 2010, 7:40
Can you explain the reasons of your opinion?
I have try to buy it but I have encountered some problems with ACE lab.
They ask me to pay very expensive taxes of russian custom and also they will ship it after 120 days after payment.
I hope they will solve faster this trouble because now is not a very friendly trading :|
PostPosted: March 8th, 2010, 7:53
Let me give u some statistics, average ace flash solved 2 out 10 cases. updates rarely maybe once or twice a year...then TS TS TS.......Euro.....Euro....no Euro no Talk=dont ask :D
PostPosted: March 8th, 2010, 8:23
heacrash so I assume you don't use ace flash do you use softcentrr instead?
if so how do u find it
thank-you
PostPosted: March 8th, 2010, 8:40
I have owned Ace Flash for a while but I got so pissed off by unsupported chips all the time, and had to rely on tech support which sometimes taken forever to help out. I finally decided to make a switch to soft-centre, it is not perfect but 100 times better than ace.
You cant sell any of ACE's products, i am stucked with it.......as it is non transferrable. :twisted:
PostPosted: March 8th, 2010, 12:03
Yes, I have the same failures :)
Contact with Ace, they promising correct this in next update. But i wait since October 2009, now we have March 2010 and update is not released yet. Even PC3K Flash version 3.0 beta don't work. The same failures, maybe little rarely.
Waste of money...
PostPosted: March 8th, 2010, 12:08
Contact with Ace, they promising correct this in next update. But i wait till October 2009, now we have March 2010 and update is not released yet. Even PC3K Flash version 3.0 beta don't work. The same failures, maybe little rarely.
Waste of money...
Hei ... now anybody disappointed about PC3K flash?
I have read before about many enthusiast users ......is not?
PostPosted: March 8th, 2010, 19:48
have you made sure that the pins are clean and not bent.
PostPosted: March 8th, 2010, 19:50
Hi Craig
yep, definitely straight as can be, this happens so far on 2 chips, i am also using an IR stattion to remove the chips so they are coming off perfectly clean and aligned
thx
PostPosted: March 8th, 2010, 20:01
In my cases it's not the problem with dirty pins. Soft just hangs and generate a lot of errors.
PostPosted: March 9th, 2010, 4:13
what version of os are you using on your pc system
is it 32bit or 64 bit
are you by anychance using windows 7
as there no drivers out for this device at all.
so that could be the problem there.
if not it might be a faulty unit ????????
PostPosted: March 9th, 2010, 5:48
32bit system XP pro.
The same problem on other computer. It is unambiguous problem with reader.
I just use Softcenter reader, and PC3K flash catch the dust.
Maybe in the future it will be a good tool...
PostPosted: March 9th, 2010, 17:58
wow a lot of money to spend on a product that does not work.
possible it could be the unit at fault or the reader where you put the ic chip in.
