PC3K DE and a Nand Programmer to recover a USB Flash Drive?
Posted: June 2nd, 2008, 17:48
by thatdellguy
This may sound like a long shot or I may not know what I am talking about. Couldn't you read a nand chip with a good programmer, write that image to a hard drive, then use PC3K Data Extractor to reconstruct the data? DE is able to reconstruct a damaged translator. Just curious if anyone has tried it. Thanks.
Re: PC3K DE and a Nand Programmer to recover a USB Flash Drive?
Posted: June 4th, 2008, 11:18
by pcimage
No it wont.
The majority of memory chips in use used in digital storage media are called 'NAND FLASH MEMORY CHIPS'. These are linked to a mini-processor that utilises built-in 'wear levelling' algorithms - which mean that each block of data is written to or erased an equal number of times. So, when you write your data, it does not necessarily go in sequence and if you are overwriting a file, it will not go back in the same place as it was before. The mini-processor keeps track of where the blocks are and the sequences in tables and when accessed, presents it to your computer (or camera) as normal so you wouldn't know that anything different is happening.
You need specialist hardware to read any NAND FLASH memory (Including service area data), and software that recognises most of the wear levelling algorithms used by manufacturers so you can put the data blocks in the correct sequence and therefore recover your data.
PM me if you need something recovering.
Cheers
Sean
Posted: June 4th, 2008, 15:51
by thatdellguy
It was just one of those crazy, late night, over caffeniated ideas I had. I knew about the wear leveling but figured DE could reconstruct the data almost like a bad translator.
Posted: June 6th, 2008, 13:49
by Amarbir[CDR-Labs]
No ,
Each MCU Used Will Have its Own Sweet Way Of Storing the Data On NAND Flash Memory,so Not Possible Using your Method
Posted: June 6th, 2008, 16:16
by pcimage
Amarbir wrote:No ,
Tell me about it!
They all seem to use different hideous methods of encoding the data.
Including byte-swap, byte inversion, striping across multi chips (or internally across multiple banks), block rotation etc etc...
Blatent plug mode = ONI can offer flash memory recovery to all hddguru members at a special fixed price, PM me for details.
Blatent plug mode = OFF
Posted: June 6th, 2008, 22:02
by vrocco
We'd rather have some info about the techniques and equipment you use I think
Posted: July 22nd, 2008, 16:37
pcimage wrote:Amarbir wrote:No ,
Tell me about it!
Hi Sean ,
That Was a Good One
Posted: August 6th, 2008, 7:45
by hddguy
Acelab are bringing out their own Flash Recovery PC3000 utility soon. You can read about it at the acelab website.
Posted: September 24th, 2008, 6:43
by Money fan
hddguy wrote:Acelab are bringing out their own Flash Recovery PC3000 utility soon. You can read about it at the acelab website.
Well, I lke this News
If they do it so good like all PC-3000 before, I want it!
Posted: October 7th, 2008, 5:33
by hddguy
Anyone have it yet?
Posted: November 17th, 2008, 4:54
by Money fan
I bought it - I will send you my opinion
Posted: November 29th, 2008, 18:08
by TS2
Money fan wrote:I bought it - I will send you my opinion
Have you bought it yet?
