HDD GURU FORUMS
http://forum.hddguru.com/
What part is broken ?
http://forum.hddguru.com/viewtopic.php?f=10&t=9740
Page 1 of 1
Author:  sigitharjono [ August 25th, 2008, 7:06 ]
Post subject:  What part is broken ?
Dear : all
I have USB Kingston Data Traveler 4 GB. It detect Removable Disk in Windows and on the propertis the controller detect SKYMEDI USB Drive USB Device , the lamp is on and off for every one second and continuesly and I want to ask "What part is broken ? bad join at the controller or bad controller. (please see the a picture)
thanks a lot
Picture 001.rar [17.32 KiB]
Downloaded 1230 times
Author:  pcimage [ August 25th, 2008, 9:16 ]
Post subject:  Re: What part is broken ?
In disk manager, is it seen as 4Gb or 0 bytes?
Author:  sigitharjono [ August 25th, 2008, 20:57 ]
It is seen as unreadable, three days ago I have some problem with my trascend 2 GB and I can repair it with only hot air gun that I applied at controller to repair bad join.
thank a lot
Author:  thatdellguy [ August 25th, 2008, 21:18 ]
The camera's focus is broken.
Author:  scratchy [ August 30th, 2008, 3:39 ]
You cant really tell from the light flashing as it will flash under a number of failures..
It could be the crystal oscillator - this is biggerest problem in these devices.
If you need the data, then search google for
data recovery dead memory
in your country, there are a few companies around the world that can do this.
<itch>
http://www.phpbb.com/
