 Post subject: ROM required for WD1600JD
PostPosted: May 13th, 2010, 13:10
WD1600JD-75HBB0
The SATA power connector on this drive had the polarity lug missing, so I'm guessing the power was put in the wrong way round.
Oddly enough the PCB actually survived but the ROM didn't. Swapped the ROM chip onto another PCB and the drive would not spin up, put the good ROM chip onto the patient PCB and the drive spun up but no ID (due to wrong ROM version) but could read SA OK.
According to mod 41 the ROM version is 21.0WJ, and none of my ROM's are anywhere near this (all 08.xxx)
Cheers
 Post subject: Re: ROM required for WD1600JD
PostPosted: May 13th, 2010, 18:18
Hi Sean,
Checked
Family EAGLE i have something here 21.CWJ
I Have Prepared a PCR file.
Check the URL in messenger for download it.
ZeBong
" Россия еще раз"
PostPosted: May 14th, 2010, 8:04
Hi Jose,
Thanks for that, but it did not work.
But I have got it working, I'll msn you the details :-)
Cheers
Sean
Users browsing this forum: No registered users and 28 guests
