Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: PCB
PostPosted: September 3rd, 2010, 7:21
I was being facetious.
In fact when I get a job with a blown fuse, I don't just replace the fuse. I survey and test the board and components, looking for likely culprits, reflowing dry solder joints, inspecting the PCB for cracks, etc. I then replace the fuse and test for thermal issues by heating and cooling the board. I also tap test for dry joints or loose connections. Then I soak test the equipment, overnight or longer if necessary. I also power cycle it to test for power-on surges.
Funny, I never see you tell this to anyone...
PostPosted: September 3rd, 2010, 7:25
It's not trivial work, but it's also not difficult. In fact a TV tech's job is much more demanding.
I am sure a brain surgeon has a demanding job, but Im pretty sure he could not save a spindle siezed Seagate :wink:
Also, a TV does not contain crucial irreplacable data, and I would guess all components of a TV can be replaced, and the work is all based on electronics. The two industries cannot even be compared...
PostPosted: September 3rd, 2010, 7:34
A brain surgeon would have no trouble removing a diode. Nurse ... flush cutters, please.
I agree, there is no scope for intimidation in the TV repair game. ;-)
